barricade88 Posted February 12, 2013 Report Share Posted February 12, 2013 I'm 19 and need help with my wiring, I need a light switch for a 620 and need a new wiring harness. I dont have tail lights and instruments because the clips are bad. an cant find a store that carries them. Anything you have that can help that please let me know. Ill buy it all from you! Thank you! (360)771-0493 Quote Link to comment
datzenmike Posted February 12, 2013 Report Share Posted February 12, 2013 Clips? what are these? You mean the plastic connectors that plug together? Are they melted or something? The clips that hold the fuses??? FUSE Tail, license, marker and instruments come on on the first position on the headlight switch. It is powered from a separate 10 amp fuse so replace it first. Do NOT TRUST A FUSE BY LOOKING AT IT. replace it with a new one. On the fuse box it would be the fuse furthest from the driver and to the left side. It would have a Green/Blue stripe wire going to it if you can see it. FUSE BOX Corrosion can prevent a fuse from making good contact. This can lead to a resistance and this will cause heat to build. Heat in turn can take the temper out of the clips that hold the fuse making matters worse. Unscrew the box and pull the two plugs off. Soak overnight in a mixture of vinegar and /or lemon juice. In the morning the copper/brass will be shiny new. Rinse and install. If heat has damages the clips the best thing is to replace the box. Quote Link to comment
barricade88 Posted February 12, 2013 Author Report Share Posted February 12, 2013 It's not the fuses, mine are all new, I need new male and female connectors. An yeah the plastic connectors. Quote Link to comment
datzenmike Posted February 12, 2013 Report Share Posted February 12, 2013 What could have happened to them???? Quote Link to comment
Dawa Posted February 12, 2013 Report Share Posted February 12, 2013 you could just say f the connectors for now and just wire them up together til u source them Quote Link to comment
barricade88 Posted February 13, 2013 Author Report Share Posted February 13, 2013 its really hard to ghetto rig them. and i dont know what to do... Quote Link to comment
Laecaon Posted February 13, 2013 Report Share Posted February 13, 2013 Hard to tie them together? Erm... You could use a new style of plug/connector. Go to the JY and cut a few plugs off of new cars, leaving a few inches of the wires on either side. Make sure the connector has enough wires to work with your current setup. You may want to test the connectors at the JY to see if its going to be a nice and easy one. Go home and butt connect the wires from the plug to your harness wires. Quote Link to comment
barricade88 Posted February 13, 2013 Author Report Share Posted February 13, 2013 Yeah it just gets really hot and my female connectors are coming out or breaking Quote Link to comment
Laecaon Posted February 13, 2013 Report Share Posted February 13, 2013 Well you need to figure out why its getting hot. Quote Link to comment
barricade88 Posted February 14, 2013 Author Report Share Posted February 14, 2013 I think it's because the H4 headlights I put in Quote Link to comment
crackerjack69 Posted February 14, 2013 Report Share Posted February 14, 2013 I've got a few harnesses in the garage, and light switches. Down in NoPo... Quote Link to comment
Laecaon Posted February 14, 2013 Report Share Posted February 14, 2013 Your tail light connectors are getting hot because of your headlights? And why would H4s do anything? They are the same wattage as stock, unless you bought some of those 110watt H4s... Or you messed up the wiring, which should never have been touched, as H4s are direct plug in... Quote Link to comment
barricade88 Posted February 16, 2013 Author Report Share Posted February 16, 2013 My lights have that little light under the actual bulb, someone said that could cause it to heat up Quote Link to comment
crackerjack69 Posted February 16, 2013 Report Share Posted February 16, 2013 Your tail light connectors are getting hot because of your headlights? And why would H4s do anything? They are the same wattage as stock, unless you bought some of those 110watt H4s... Or you messed up the wiring, which should never have been touched, as H4s are direct plug in... He's all good. Just needed a light switch and repair the loose connector @ the HL switch connector. We're gonna do some work on the current wiring scenario, make it a little prettier :D Quote Link to comment
barricade88 Posted February 16, 2013 Author Report Share Posted February 16, 2013 Ha, thanks man!! I really appreciate it! My light switch is in the dash with the fiber optic and my fuses are covered 1 Quote Link to comment
pharouh Posted February 18, 2013 Report Share Posted February 18, 2013 Here's where you can get the plugs and connectors. I bought a kit and it was a lifesaver. I had to fix all the connections that the P O had half assed. http://www.vintageconnections.com/ Quote Link to comment
