Gottagoon Posted February 10, 2013 Report Share Posted February 10, 2013 This seems like a simple question but my eyes are nearly blood shoot with all the web research i've been doing, and still don't know if I should buy this SR20 motor out of a Sentra for $500. I just blew up the L20 in my Goon. Want to do the conversion. I also don't know if the SR20 will bolt up to my 5 speed trany...........anybody ? Quote Link to comment
datzenmike Posted February 10, 2013 Report Share Posted February 10, 2013 The distributor sticks out the back of the head and will hit the firewall. The mounts are either different or non existing... at least on the sides of the block. Not sure about the bolt pattern for a RWD 5 speed.but won't fit the L20B trans. Quote Link to comment
RedBanner Posted February 10, 2013 Report Share Posted February 10, 2013 to slow i geuss.. Quote Link to comment
Gottagoon Posted February 10, 2013 Author Report Share Posted February 10, 2013 Duh,....the distributor out the back......well now i feel foolish. But thank you datzenmike. maybe the block would work but then again maybe not. I don't need to make this a bigger project than need be. I should just find a complete donner car........ Quote Link to comment
Gottagoon Posted February 10, 2013 Author Report Share Posted February 10, 2013 KA will bolt up to my 5 speed, right ? Quote Link to comment
hobbes_the_cat Posted February 10, 2013 Report Share Posted February 10, 2013 The fwd sr motor will not bolt up to a rwd sr trans, so no the block won't work either. Quote Link to comment
72240z Posted February 10, 2013 Report Share Posted February 10, 2013 Shit if only the FWD sr20 was worth anything lol. You cant swing a cat in a junk yard around here without hitting one. Quote Link to comment
datzenmike Posted February 10, 2013 Report Share Posted February 10, 2013 KA will bolt up to my 5 speed, right ? . I just blew up the L20 in my Goon. Want to do the conversion. I also don't know if the SR20 will bolt up to my 5 speed trany...........anybody ? No. Depends on what 5 speed you have in there. 71B or 63A. You could find a Z series front case and swap it on to your L 5 speed and the KA would then bolt up. If you have a 71B a KA 5 speed front case will bolt on and convert it. You have options. But as is a KA won't bolt up (at least not properly) to an L series transmission. Here's some reading for you. It may help you make a choice. I don't know who this guy is but this is the most comprehensive listing of Datsun transmissions on the internet. It's geared towards 510 swaps but the information is good for any car. There's even small tricks to ID transmissions when junk yard shopping, what years and cars they were in, the usual ratios, doglegs, Nismo 5 speeds, relative power handling, some history. Even automatics. And pictures!!!! Shit if only the FWD sr20 was worth anything lol. You cant swing a cat in a junk yard around here without hitting one. I know. Plug the dizzy hole and run crank fire ignition. Still need a tranny. Quote Link to comment
MikeRL411 Posted February 10, 2013 Report Share Posted February 10, 2013 DatzenMike, great reference, thanks! Quote Link to comment
