Ejnave Posted February 5, 2013 Report Share Posted February 5, 2013 Hey guys just recently bought a 75' 620, I'm new to datsuns, abc even newer to ratsun. Truck looks and stops great with original brakes(drum). In the near future I'd like to do the ka swap with an lsd but I'd like to convert to 4 wheel disc. My only concern is.... Truck is slammed with 17's and I'm worried about a wider track width and tires rubbing, with the addition of discs. Any insight and experience would be helpful guys. I'd appreciate it! Quote Link to comment
Dat Lurka Posted February 5, 2013 Report Share Posted February 5, 2013 If you use the right rear and do a spindle swap up front there should be no change in track width. Use the search bar to see 100 other 620's slammed on 17's with disc brakes. Quote Link to comment
Ejnave Posted February 5, 2013 Author Report Share Posted February 5, 2013 Thought I read something about choosing the correct rotors up front? Effecting offset? Quote Link to comment
datzenmike Posted February 5, 2013 Report Share Posted February 5, 2013 Only way to put front disc brakes on a 620 is to get or make a caliper mount bracket that bolts onto the spindle you have now. BEEBANI makes a kit and you supply the calipers and rotor. There is no way to just bolt later disc brakes onto a pre '78 truck. This even doubly true on the back. BTW rear disc brakes don't stop any better than drums. They are easier to maintain as you don't have to constantly adjust them, easier to change the pads, can tolerate more heat without fade than drums but you would have to race them to appreciate this, and they look cool. Quote Link to comment
kelowg Posted February 5, 2013 Report Share Posted February 5, 2013 With the right rotors offset changes by 5-6mm,width of rotor hat. Quote Link to comment
Ejnave Posted February 5, 2013 Author Report Share Posted February 5, 2013 Thanks guys I will be getting In touch with beebani soon. Just concerned with my tires rubbing, just wanted to get a little insight before I started! Seeing as it has been done plenty of times before beebani will know best. Thanks again! Quote Link to comment
mklotz70 Posted February 5, 2013 Report Share Posted February 5, 2013 There's barely any extra width added with Bee's brake setup. The drum is about 6mm thick at the lug bolts.....it comes off, the rotor thickness at the same point is about the same 6mm. It's within an 1/8" if I remember right. My kit adds about 5/8" to the track width......I think.....I measured it, I just don't remember off hand. Backs....same thing.....should have same track with with disc as with the drum. Quote Link to comment
krecs Posted February 16, 2013 Report Share Posted February 16, 2013 if you need more info let me know i make those kits i recomend wilwood set up datsun parts llc sell them for me thanks Quote Link to comment
Cheko620 Posted January 20, 2014 Report Share Posted January 20, 2014 Krecs, I tried to message u but it wouldn't let me. I want to know if you have a kit for sale? Quote Link to comment
