Oil on back window... Main seal?
  • Replies 13
main seal is at the back of the engine not transmission only thing i can think of is possibly the output shaft seal but that is still to far forward as for your transmission unless someone swapped the bellhousing it is not from a z car it might be a z series transmission for a nap z engine however
That hole in the bed could cause a neg pressure/vacuum and weird turbulence that could pull oil spray from anywhere and it doesnt take a whole lot of oil to make a mess on a window... Check EVERYTHING.
If its gear oil from your diff or trans you should be able to smell the difference.
Ya gear oil is going to stink and engine oil is going to have a petrol smell.
You have to bite the bullet and search everything in depth. If you find a general area but cant pin point then make sure you clean up the whole area well so you can see for sure.
That would be the pinion seal. Most auto parts stores will have it just use the Nissan # 38189-P0101 to cross reference it.
Before going any further grab the pinion flange where it bolts to the driveshaft and try to move it to the sides or up and down. If there is any movement other than turning the bearing is shot and a new seal won't help.
Mark the flange/driveshaft relationship and remove drive shaft. Block tires so they don't move, place in 5th gear and have someone hold the brakes on hard! Now you should be able to loosen the pinion nut. Tap the back side of the flange with a hammer and drive it off the pinion. It will take a while but it will slowly move forward and off. A gear puller will also work if you have one. Do not disturb the pinion. You should be able to carefully pry out the old seal and equally carefully hammer in the new seal. Use a block of wood. Grease the flange so it does not tear the new seal when installing and also so it does not start up dry. Tighten the pinion nut to 100-123 ft lbs.
