Guest DatsuNoob Posted May 3, 2007 Report Posted May 3, 2007 Can one of you guys tell me where to hook up the electric choke wire on my 76 620? I know it needs to be an ignition wire, or one that is powered when the key is in the on position? Dont know which one. Today, (with the help of Pumpkn210 we got her blowin flames out the carb, gettin closer :D) got her fired up and runs like crap, but it's a step in the right direction. I guess that's to be expected with an out-of-the-box weber. Quote
datzenmike Posted May 3, 2007 Report Posted May 3, 2007 The auto choke heater on the carb is connected to a blue wire. Look for a loose blue wire hanging just behind the carb above the throttle cable. If not connect it to the choke heater relay on the pass side fender. This relay should have 4 wires going to it, a blue (that you connect to) a black, a yellow and a white w/ blue stripe. This relay powers the choke only if the engine is running. If the choke is connected to the ignition and the motor stalls in the driveway while you are inside warming up with a coffee, it will heat the choke and turn it off. When you go out the choke will be off, and it will be hard to re-start it. Just a thought. Quote
banzai510(hainz) Posted May 3, 2007 Report Posted May 3, 2007 Your stock carb should have had a wire to the choke in the first place. otherwise your choke would be ON all the time.unless some one removed it out and installed a manual one or wired it back!!!!!!! Quote
Icehouse Posted May 4, 2007 Report Posted May 4, 2007 By "Out of the box" do you mean NEW? If so that baby should run like a champ. Did I miss pics of your rig? Quote
Guest DatsuNoob Posted May 4, 2007 Report Posted May 4, 2007 Yeah, Hainz, my stock carb had the elec. choke removed and a manual cable put in its place (my weber has the connection, I'm just looking for the wire to splice into). It's also an electrical nightmare. I got wires with butt connectors hangin here and there. I'm assuming the old man who owned it before me thought he was electrically inclined, and figured he didnt need them or something cause he messed with some wires near the coil. I didnt see a hanging wire on the firewall like your rig. Icehouse, yeah it's straight outta the box, brand spankin' new I figured these things need adjustments as they probably dont come pretuned. First I gotta get this thing running, it was sputtering(bad timing probably, although it was set perfectly at 10 deg. before removing the distributor to fit the header in., now who knows) Pumpkn210 will probably come over today after work, but if we can't get it would someone be able to come over and lend a hand sometime in the near future? I'll supply the beer. Quote
Icehouse Posted May 4, 2007 Report Posted May 4, 2007 I work in Puyallup, PM me and we could make arraignments, I may be laid off for the next week though :D But I would mind swinging down there, expecially if my driveline fixing my vibration problem :D Quote
banzai510(hainz) Posted May 4, 2007 Report Posted May 4, 2007 Find that wire as Mike said the blue one. Or all else fails you could adjust the plactic round part(the coil part) adjust it till its open when its cold. You wont have a choke then so have to pump the pedal before start up. But best to find the choke wire. Most DGVs will run very well (when new) not much to adjust Quote
slodat Posted May 4, 2007 Report Posted May 4, 2007 I second Hainz's "Most DGV's will run very well (when new)..." The electric choke on my was very good... Quote
