erichwaslike Posted January 29, 2013 Report Share Posted January 29, 2013 i need an l series motor, 4 cyl. in arunning shape. i have the intake and exhaust, just need a running long block. budget tops out at 200+/- depending on the motor and such. l16/18/20 i just need this truck running so i can get around. the l16 in it has a bent valve that wont return. i will offer up the l16 in it for some trade value if it helps. also willing to trade fabrication work. heres a link ot my shop i own https://www.facebook.com/JapanAutoEngineering let me know what you guys have in socal. Link to comment
Eagle_Adam Posted January 29, 2013 Report Share Posted January 29, 2013 you need to move to oregon :/ Link to comment
banzai510(hainz) Posted January 29, 2013 Report Share Posted January 29, 2013 why dont you just swap the head. Most stock L16 heads are pretty cheap all together. Like 25$ 2/3 hours your done. Link to comment
erichwaslike Posted January 29, 2013 Author Report Share Posted January 29, 2013 i would take a head too but i was just looking for simple route. and was hoping for a l18/20. and a head swap will cost me about 50-75 so if i can get a motor for 150ish then id go that route. i hate dealing with timong cams and such and hoping that the head gasket was torqued propper. Link to comment
banzai510(hainz) Posted January 29, 2013 Report Share Posted January 29, 2013 you want a L18 then not a L20 unless you know the clutch/pressureplate size. like hope its a 200mm from already another 510 no better time than now to learn a head gasket. They EZ. just have the timming chain tool. i already made a vedio on timming of cam How much ezer can it get? Link to comment
DREWSDIME Posted January 29, 2013 Report Share Posted January 29, 2013 Come get my L16 from my 68 it runs needs rear main seal. How good of runner do you want? For what? Link to comment
DREWSDIME Posted January 29, 2013 Report Share Posted January 29, 2013 Help me pull motor and trans out of my 68 and just help me get KA in car you can have L16 1 Link to comment
erichwaslike Posted January 29, 2013 Author Report Share Posted January 29, 2013 you want a L18 then not a L20 unless you know the clutch/pressureplate size. like hope its a 200mm from already another 510 no better time than now to learn a head gasket. They EZ. just have the timming chain tool. i already made a vedio on timming of cam How much ezer can it get? i know how t do it all i just dont wanna Come get my L16 from my 68 it runs needs rear main seal. How good of runner do you want? For what? i need it for my 521. my jetta blew up so i started driving the truck friday, sunday it was making alot of valve clatter so i pulled the vc and a lash pad had kicked out cause a valve is bent and wont return to the top. needs to run decently. i have intake and all that Help me pull motor and trans out of my 68 and just help me get KA in car you can have L16 when you wanan do it? Link to comment
banzai510(hainz) Posted January 29, 2013 Report Share Posted January 29, 2013 My car broke. I need it fixed i know how t do it all i just dont wanna !!!!!!! DREWSDIME is the man Link to comment
erichwaslike Posted January 29, 2013 Author Report Share Posted January 29, 2013 My car broke. I need it fixed i know how t do it all i just dont wanna !!!!!!! DREWSDIME is the man funny... im still doing all the work. i just dont wanna deal with internal stuff right now. timing, adjusting valves adn all that if i can get a whole motor... and i did! and yes jeff is the man. Link to comment
decoy12 Posted January 29, 2013 Report Share Posted January 29, 2013 I got the 620 driving again, if you guys needed help transporting the L16. Link to comment
