A14/A15 Stuff Wanted!
Lookin to do a mild build on an A15. Lookin for some performance stuff. Maby A15 short block, GX Head, Pistons, Hot Cam, Intake, Carb, Regular Pattern 5-speed. You know, the fun stuff! PM me or something like that.
Thanks
Dave Patterson
"Pumpkn Operator"
  • Replies 15
I want it! how mutch for it. Is it a dogleg or reular pattern? How mutch $? I get a grip of moolah on the 10th. Want this stuff bad! got a place to do the work and am buying a 79 210 Goon to drive in the meen-time and in-between time.
Well I got a dogleg in storage(Icehouse wont give it back!) And am buying a 79 210 goon for its reg. pattern. But I am definately interested in the GX engine! PM me with your # and how mutch!
1979 Datsun 210 5-speed is the dogleg pattern. 1980-1982 5-speeds are the regular pattern. But somebody might have swapped them. These are the mid-duty 60-series transmissions.
63-series 5-speed is the heavy-duty dogleg, very heavy, holds up well even behind supercharged A14s.
i've never seen a datsun 210 with a factory installed dogleg. are you sure?
afaik, only the a-series usa spec datsun to have a dogleg 5spd was the '78 b210 gx, and it was a 63a
afaik, the 60a dogleg was for the jdm gx exclusively
I can say that Icehouse and I have seen a 79 210 with a regular A14 and a factory Dog-Leg 5. You have to remember that the 79-80 year change was a blurry time! I have seen multiple 80 model year 210s with the 79 body on them(Mine Included).
don't get me wrong, it's good news to me, but i just find it hard to believe datsun used a 63a on the '78 b210 then switched back to a 60a for the '79 210. if the '79 210 did have a factory dogleg, it must have been a 63a. please prove me wrong!
Yes, the B310 changed mid-1980. Early 1980s had round headlights, later 1980s had square headlights.
5-speed Details (for A-series engines)
All B-210 5-speeds are 63-series. Only available 1976-1978 (1974 & 1975 USA models had no 5-speed option)
63-series 'big boy' 5-speed for A-series engine
63-series vs 60-series 5-speeds
From the Nissan Factory repair manuals:
* 1979 B310 5-speed: FS5W60L (dogleg shift)
* 1980-1982 5-speed: FS5W60A (regular shift)
60A vs 60L 5-speed Tranmissions for A-series Engine
My guess is this:
1. They needed a 5-speed for USA fuel economy. The B110 5-speed was too light for the A14 engine. So they modifed the the 63-series normally used behind the L-engine to fit the A-engine
2. By 1979 they had a new mid-weight 5-speed ready (60L)
3. There were problems with the 60L they quickly modified it into the 60A. The fifth-gear location and mechanical design is quite different... just a guess.
I am not sure what dogleg tran it is. Icehouse still has it:mad: I was just saying that it was a dogleg.
I have found it hard to find a non dog 5 for my car. And am ending up buying a 79.5 goon to swap it from!
I actually did finally clean out my shed so I can get to it :D I started school so I'm only at Franks once a week or so. If you want to pick it up in seattle I can toss it in the back of my truck.
