bikesnbenzs Posted January 16, 2013 Report Share Posted January 16, 2013 or , are 520 and 620 transmissions interchangeable ? Quote Link to comment
merlin Posted January 16, 2013 Report Share Posted January 16, 2013 no starter is on the wrong side ... what engine are you trying to put in what... Quote Link to comment
bikesnbenzs Posted January 16, 2013 Author Report Share Posted January 16, 2013 sd25 in a 74 620 Quote Link to comment
wayno Posted January 16, 2013 Report Share Posted January 16, 2013 sd25 in a 74 620 You need to go back and get the transmission/flywheel/starter minimum, and it would be smart to get the whole diesel wiring harness, but that would be my opinion. Do the injection pump lines look like this? Quote Link to comment
bikesnbenzs Posted January 16, 2013 Author Report Share Posted January 16, 2013 they look different then that Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 620 transmission fits L-series engines, not SD-series engines. Quote Link to comment
wayno Posted January 16, 2013 Report Share Posted January 16, 2013 Do your injection pump/lines look like this then? Quote Link to comment
bikesnbenzs Posted January 17, 2013 Author Report Share Posted January 17, 2013 yes that , what is the difference? Quote Link to comment
wayno Posted January 17, 2013 Report Share Posted January 17, 2013 Wow, I have never seen another VE type injection pump in the USA on a 720 SD diesel engine, I had mine shipped from Australia. You have one of the few SD engine series injection pumps that are fairly easy to turbocharge, but you need a transmission for it, you need to look around for a datsun/nissan SD22/25 transmission, beg for one if you have to, you are lucky that you have this type of injection pump, it is a lot easier to set up to work off your ignition/key also. If you cannot find a diesel transmission, you quite likely can make a early datsun roadster transmission work, but I have not personally tried it yet, it has the same transmission case bolt pattern as the diesel, it also has the starter in the same place/position. If all else fails you can sell me the engine. :lol: :lol: :lol: :lol: I know a little about these diesels, I have an SD25 diesel powered 1969 521KC I put together a few years ago, I actually have 3 running SD series diesel trucks. This is a link to the diesel truck I put together. http://community.ratsun.net/topic/22928-1969-datsun-kingcab-project/page__view__findpost__p__375219__hl__wayno__fromsearch__1 Quote Link to comment
wayno Posted January 17, 2013 Report Share Posted January 17, 2013 I just re-read the heading of this thread, and you are wanting to use an auto transmission, that is going to be tough, the only way I would think that might be possible is if the front few inches of a diesel transmission case were to be welded onto the auto front case after cutting the proper amount off of it, and a flywheel would have to be made or found to work with the diesel starter, maybe the stock flywheel could be machined down to work with the torque converter, anyway you look at it, it is likely going to be a lot of work. Have you ever drove or even been in a SD22/25 series equipped truck? They are not that powerful of an engine, but they get decent fuel mileage. I do not believe that the SD series engines ever had an automatic transmission anywhere in the world, well except maybe a forklift automatic, but that would not likely work in an automobile application, and I don't believe that the roadsters ever had an automatic option either. Quote Link to comment
Cahoon520 Posted January 17, 2013 Report Share Posted January 17, 2013 Or you could use a 727 automatic from a IH Scout that had a sd33 in it.... Quote Link to comment
wayno Posted January 17, 2013 Report Share Posted January 17, 2013 Or you could use a 727 automatic from a IH Scout that had a sd33 in it.... This I did not know, an auto that will bolt to a SD series engine, are they hard to find? Quote Link to comment
datsunaholic Posted January 17, 2013 Report Share Posted January 17, 2013 This I did not know, an auto that will bolt to a SD series engine, are they hard to find? Seen an IH Scout recently? Let alone a Diesel one? IH guys with their SD33s seem to really want to hold on to them. Now, perhaps an SD20/SD22 Diesel Nissan Cedric might have an Automatic option... of course, they only existed in Europe and Asia. Quote Link to comment
merlin Posted January 17, 2013 Report Share Posted January 17, 2013 Seen an IH Scout recently? Let alone a Diesel one? IH guys with their SD33s seem to really want to hold on to them. Now, perhaps an SD20/SD22 Diesel Nissan Cedric might have an Automatic option... of course, they only existed in Europe and Asia. lol there' over 400 of them on the same lot as the "patrol hoarde" so many you can see them from space. that Said, there was only 1 diesel among them if I remember correctly. Bikesnbenz, if you get stuck and decide to manual, I have a diesel 5 speed i can sell you for my time to get it off and packed $100, the shipping from canada will kill you though. Quote Link to comment
Cahoon520 Posted January 18, 2013 Report Share Posted January 18, 2013 merlin, I will take that tranny of your hands if he doesn't want it! Quote Link to comment
merlin Posted January 18, 2013 Report Share Posted January 18, 2013 merlin, I will take that tranny of your hands if he doesn't want it! Yah sure! its in a snowbank right now but come the thaw you can have it and anything you want off the SD22 its attached to. Quote Link to comment
datzenmike Posted January 18, 2013 Report Share Posted January 18, 2013 Diesel_Jeep_CJ 10A Has SD bolt pattern on Chrysler 3 speed TorqueFlite automatic. Quote Link to comment
Cahoon520 Posted January 18, 2013 Report Share Posted January 18, 2013 Yah sure! its in a snowbank right now but come the thaw you can have it and anything you want off the SD22 its attached to. Sounds Good! I will be in Kelowna in May again maybe we can meet up then. Quote Link to comment
merlin Posted January 18, 2013 Report Share Posted January 18, 2013 odds are i'll be driving my 521 so that will work. Quote Link to comment
Cahoon520 Posted January 18, 2013 Report Share Posted January 18, 2013 Good cause we need more trucks there this year! Quote Link to comment
wayno Posted January 18, 2013 Report Share Posted January 18, 2013 Diesel_Jeep_CJ 10A Has SD bolt pattern on Chrysler 3 speed TorqueFlite automatic. The article talked about the injection pump being vacuum controlled, while the SD25 engine bikesnbenzs has is the VE type injection pump, a lot of hassles are bypassed because of this, I wonder where he found this engine with that injection pump, I had to have mine shipped from Australia. I have a feeling that the Chrysler 3 speed TorqueFlite automatic is not an easy to find transmission either, but I could be wrong, I would just stick with the L block if I were him, and he should sell that engine to me. :lol: :lol: :lol: Quote Link to comment
ggzilla Posted January 18, 2013 Report Share Posted January 18, 2013 the Chrysler 3 speed TorqueFlite automatic is very easy to find, it was used by millions of vehicles in the 1960s, 1970s and 1980s. The SD version of the TorqueFlite is about as rare as an IH Scout II. When's the last time you saw one? Quote Link to comment
