Janksun Posted December 11, 2012 Author Report Share Posted December 11, 2012 Looking for random parts and found this in the junkyard! Took the doors an tailgate and I'm going to make some half doors and a tube gate with the Datsun letters on it! Started tearing down the engine today. Looks to be in runnable condition, just gotta get some gaskets and put everything back together. Then I have to figure out the wiring... Good thing I have a new/used harness coming! Quote Link to comment
Janksun Posted December 11, 2012 Author Report Share Posted December 11, 2012 Forgt to post the pic lol Quote Link to comment
datsun 160J SSS Posted December 14, 2012 Report Share Posted December 14, 2012 i need parts from that king cab . if you have any questions about your 620 4x4 email me mbkornuth@msn.com . I have a 620 king cab jeep change over Quote Link to comment
Eagle_Adam Posted December 14, 2012 Report Share Posted December 14, 2012 http://portland.crai...3435331235.html Quote Link to comment
Janksun Posted December 15, 2012 Author Report Share Posted December 15, 2012 Thanks for looking out. Right now I'm focused on getting the truck running before I go about swapping axles and what not. Have some parts coming from rock auto! Quote Link to comment
secret sponge Posted February 16, 2013 Report Share Posted February 16, 2013 You shouldn't have to swap axles if you don't feel the need, the front disk brakes off of a k5 blazer fit nicely on mine, you just need the calipers, caliper mounts, and disks, the caliper mount has a little tab you have to grind off to fit, and I would suggest the blazer MC as well (has to bed adapted to the booster though) if you plan on wheeling it though swapping axles would be smart, the factory axles will snap easily if you get stuck. And as far as gearing goes, you can check it by turning the driveline mount, so many turns to turns of the wheel is the ratio, if it takes 4.88 rotations to get 1 at the wheels, you got 4.88, hope that helps. Quote Link to comment
