WTB shotened axle for 510
  • Replies 5
Dude, wtf? Type correctly. Next, go look up your local driveshaft shop and have them shorten your stock driveshaft. Much less there is next to zero information. If it's a 70 510, what motor does it have, what rear diff, what transmission are you going to use, etc. Use the search function of google and put ratsun after it.
Axle? Possibly you mean a shortened driveshaft? Can I assume you have or want to swap a transmission into it? The ideal thing to do is install it and measure the distance from the end of the transmission to the flange on the rear differential, maybe draw a picture and take to a drive line shop. There are at least 4 L series 5 speeds that could bolt into the 510.
more details there is a shop in west sac that shortens drive shafts
sacramento driveshaft
also a shop in shingle springs did mine cant remember the name of the shop its off motherload drive they did a great job
