jeph Posted October 28, 2012 Report Share Posted October 28, 2012 what title says, looking to buy working 4 or 5spd tranny and driveline that will work in my 2 door stock rear end and stock l16 motor. thanks, jeph Link to comment
datzenmike Posted October 28, 2012 Report Share Posted October 28, 2012 Do you mean fit without modifications? That would be an FS5W63A dogleg... it's the same length so your drive shaft will fit, it's from a later L series motor so will bolt to the 510's L16, the 510 speedometer cable will fit it and it's on the same side. You will have to modify the rear mount slightly so it will bolt down. With a bit more work/expense you can fit a later 280z, 280zx, 810/Maxima or 620 FS5W71B 5 speed. They are all the same transmission just different gear ratios inside. You still have to mod the rear mount but in addition thew driveshaft needs to be shortened and balanced and the shifter hold enlarged to the rear. By re-routing the speedometer down over the top of the transmission the stock speedo cable can be used but if not a a 620 5 speed cable will work. You may have to find a new 17 tooth speedo pinion to match what was in your 510 to keep the speedo accurate. This is a far stronger transmission, much more common to find and has 3 choices of ratios and several overdrives to choose from. 1 Link to comment
Logical1 Posted October 28, 2012 Report Share Posted October 28, 2012 I have the 5spd Dogleg Mike is talking about, I purchased it shortly after a full bearing rebuild and only put about 5k on it. $250. I'm located 2 miles from downtown Everett. PM me if your interested Link to comment
hobbes_the_cat Posted October 28, 2012 Report Share Posted October 28, 2012 There is a stock 4 speed on Craigslist in marysville for $75. Link to comment
tdaaj Posted October 28, 2012 Report Share Posted October 28, 2012 I've got a short 4spd out of a 73 620, $50 Link to comment
jeph Posted October 28, 2012 Author Report Share Posted October 28, 2012 Do you mean fit without modifications? That would be an FS5W63A dogleg... it's the same length so your drive shaft will fit, it's from a later L series motor so will bolt to the 510's L16, the 510 speedometer cable will fit it and it's on the same side. You will have to modify the rear mount slightly so it will bolt down. With a bit more work/expense you can fit a later 280z, 280zx, 810/Maxima or 620 FS5W71B 5 speed. They are all the same transmission just different gear ratios inside. You still have to mod the rear mount but in addition thew driveshaft needs to be shortened and balanced and the shifter hold enlarged to the rear. By re-routing the speedometer down over the top of the transmission the stock speedo cable can be used but if not a a 620 5 speed cable will work. You may have to find a new 17 tooth speedo pinion to match what was in your 510 to keep the speedo accurate. This is a far stronger transmission, much more common to find and has 3 choices of ratios and several overdrives to choose from. what years 280zx fit because there is one at the junkyard by my house but its newer fuel injected z and i wasnt sure if it would still fit in my 510. Link to comment
Ranman72 Posted October 28, 2012 Report Share Posted October 28, 2012 what years 280zx fit because there is one at the junkyard by my house but its newer fuel injected z and i wasnt sure if it would still fit in my 510. all the way to 83 but not 84 and you dont want the turbo one Link to comment
datzenmike Posted October 28, 2012 Report Share Posted October 28, 2012 what years 280zx fit because there is one at the junkyard by my house but its newer fuel injected z and i wasnt sure if it would still fit in my 510. Well it only fits if you do the following.... With a bit more work/expense you can fit a later 280z, 280zx, 810/Maxima or 620 FS5W71B 5 speed. They are all the same transmission just different gear ratios inside. You still have to mod the rear mount but in addition the driveshaft needs to be shortened and balanced and the shifter hold enlarged to the rear. By re-routing the speedometer down over the top of the transmission the stock speedo cable can be used but if not a a 620 5 speed cable will work. You may have to find a new 17 tooth speedo pinion to match what was in your 510 to keep the speedo accurate. This is a far stronger transmission, much more common to find and has 3 choices of ratios and several overdrives to choose from. All years of 280zx ('79-'83) NON TURBO will 'fit'. The first year ('79) has the same transmission gear ratios as the previous 280z '77-'78. The '80-'83 have a 'close ratio' gear set compared to the earlier years and have huge 5th overdrive gears. Link to comment
jeph Posted October 29, 2012 Author Report Share Posted October 29, 2012 Well it only fits if you do the following.... All years of 280zx ('79-'83) NON TURBO will 'fit'. The first year ('79) has the same transmission gear ratios as the previous 280z '77-'78. The '80-'83 have a 'close ratio' gear set compared to the earlier years and have huge 5th overdrive gears. Thanks alot for the info! Link to comment
