2JZ260z Posted October 14, 2012 Report Share Posted October 14, 2012 Just rebuilding an L24. Could use a stock L24 points Distributor, but I heard swapping to an L28 one is relatively simple and MUCH more reliable, better revving, etc etc. If anyone has EITHER of these, wants to let em go for a decent price, I'd be hard-pressed not to buy! Randy, I know you've got some of the shit. If anyone has the L28 setup, LMK what I'd need to swap over. 1 Link to comment
datzenmike Posted October 14, 2012 Report Share Posted October 14, 2012 This will only work if you get the one with the E12 80 matchbox on it. 280zx and Maxima made up to June '81 with normally aspirated motors. This one is from a Maxima or 280zx made from June '81 ('82 model year) and is the bad ones with an E12 93 matchbox. You can swap an E12 80 onto it to convert. Notice the second set of terminals marked I and W on the right side? This has something to do with the EFI and probably some kind of ignition retard. Some time back someone on the 510 Realm used one of these matchboxes on an L20B and as the motor was revved up the ignition timing would automatically retard up to 20 degrees. Avoid them. The 6 cylinder dizzy is OK just swap out the E12-93 . Link to comment
2JZ260z Posted October 15, 2012 Author Report Share Posted October 15, 2012 Thanks Datsmike! :3 I may be able to find these in pick'n'pull then relatively cheap :3 Link to comment
datzenmike Posted October 15, 2012 Report Share Posted October 15, 2012 As I said if you only find the later zx dizzys you can swap the earlier matchbox onto it. Link to comment
Ranman72 Posted October 24, 2012 Report Share Posted October 24, 2012 what r u waiting for you know where i live have to make sure I have one though Link to comment
2JZ260z Posted October 28, 2012 Author Report Share Posted October 28, 2012 Yeha do a check. I've got a list of shit I need to get from you sir :3 Link to comment
izzo Posted October 28, 2012 Report Share Posted October 28, 2012 I believe I have a Z dist sitting in my house, not being used. I believe its a points one also. Yours for shipping if you want it? Ill double check when I get home if interested. PM me if so. I can snap a pic when I get home and reply back to your PM and go from there. Link to comment
2JZ260z Posted October 29, 2012 Author Report Share Posted October 29, 2012 Hey izzo, I super appreciate it man. It seems that, through lots of reading, the points distrib is far inferior to that of the EFI dizzy. With a simple wiring mod, I can have better, reliable spark, so I'll probably just do that. If my friend (who this is for) decides against the EFI dizzy, i'll gladly pay postage and send you some money for beer :# Link to comment
VValicente Posted March 9, 2013 Report Share Posted March 9, 2013 So to my understanding, for wiring the matchbox dizzy, C goes to coil and B goes to either straight to the body or a ground wire? Link to comment
