fat john Posted October 12, 2012 Report Share Posted October 12, 2012 ok i need some help i have a 75 620 it has a L 16 it smokes so it needs rings i picked up a 76 620 for parts it has a L 20 B so the motor now is all apart my buddy came over the other day an we miked the bore i think it was 3.36 is that the stock bore for the l 20 b? Quote Link to comment
metalmonkey47 Posted October 12, 2012 Report Share Posted October 12, 2012 Stock bore on L20B is 3.35 1 Quote Link to comment
Jayden71 Posted October 12, 2012 Report Share Posted October 12, 2012 is that all you needed help with?? 1 Quote Link to comment
fat john Posted October 12, 2012 Author Report Share Posted October 12, 2012 ya i think so thank you Quote Link to comment
datzenmike Posted October 12, 2012 Report Share Posted October 12, 2012 Not much of the L20B will fit the L16, you're further ahead rebuilding the L20B and swapping it in. The bore should be measured at 6 places inside. About 1/2" down, 2" and 3" and at 90 degrees to those. This will give a better idea of it the cylinder is tapered or oval shape. The L20B is 86mm bore. 1 Quote Link to comment
fat john Posted October 14, 2012 Author Report Share Posted October 14, 2012 thank you the l 16 in on its last leg l 20 b is it but i have to have the bore bored out it looks like the last guy to drive it had blown the head gaskit an you all know what water will do to the metal but the parts truck was cheep vary cheep Quote Link to comment
datzenmike Posted October 14, 2012 Report Share Posted October 14, 2012 Pistons fit the bore to close tolerances, so buy the oversize pistons first and give them to whoever does the boring. He should measure them and bore to fit the pistons. Quote Link to comment
fat john Posted October 14, 2012 Author Report Share Posted October 14, 2012 thank you i will Quote Link to comment
banzai510(hainz) Posted October 14, 2012 Report Share Posted October 14, 2012 Id be leary of that motor. L20 is a 6bolt crank your L16 is 5 bolt so there will be clutch issues for sizeing Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 i did the clutch on the l 16 an a rear main seal but i didn't think of that but i was thinking on putting on a new one but know i know i have to thank you for the in foe Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 an how about the head i think the l 16 has a l 20 b head ? Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 holed on if the fly wheel is off an l 20 b then im good ? Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 on the head it says u 67 on the l 20 b an on the l 16 it says a 87 ? witch is the best one to use ? Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 the first 2 are my truck the other 2 is my parts truck Quote Link to comment
datzenmike Posted October 15, 2012 Report Share Posted October 15, 2012 an how about the head i think the l 16 has a l 20 b head ? holed on if the fly wheel is off an l 20 b then im good ? on the head it says u 67 on the l 20 b an on the l 16 it says a 87 ? witch is the best one to use ? The U-67 is the best head for the L20B, the A-87 head is the best for the L18. The best head for the L16 is a 210 head. L16 and L18 have 5 bolts holding the flywheel on. The L20B has 6. They will not interchange 1 Quote Link to comment
fat john Posted October 15, 2012 Author Report Share Posted October 15, 2012 think you so i have the same fly wheel an head for the l 20 b that head is in bad shape u 67 that is what is there any other parts that i need from the l 20 b Quote Link to comment
Rays74 Posted October 19, 2012 Report Share Posted October 19, 2012 Did you say you have a 6 bolt flywheel to fit the L20B? The one from the smaller engine won't work. Tough to read your replies..... Quote Link to comment
