Enrique20 Posted September 11, 2012 Report Share Posted September 11, 2012 What is a good 4 banger engine i can slap into my 510 that has power and is kinda of modern so i can rig and install the a/c, and all the nice things. Quote Link to comment
I'm BLUE Posted September 15, 2012 Report Share Posted September 15, 2012 KA24e KA24de not sure if space for all the nice things lol ? 1 Quote Link to comment
doomdatsun Posted September 15, 2012 Report Share Posted September 15, 2012 sr20de or sr20det, also CA18DET would be cool Quote Link to comment
banzai510(hainz) Posted September 15, 2012 Report Share Posted September 15, 2012 also lots of MONEY Quote Link to comment
Boaty Posted September 15, 2012 Report Share Posted September 15, 2012 KA would be my choice, unless you have deep pockets and want to mess with boost and tuning. I have a KA24DE in mine, and it's worn out - much more enjoyable, and considerably faster than my semi-built L20B. Obviously more work than an L20B, since you have to wire in EFI, fuel pump, fuel lines, all the associated bits, likely going to have to relocate the battery, etc. I get ~28-30mpg average if I keep my foot out of it. ~25-26 if I hot rod around. I managed 35mpg on the freeway between Oregon and California, but there was lots of downhill and coasting involved, and I kept an even speed most of the way. 1 Quote Link to comment
I'm BLUE Posted September 15, 2012 Report Share Posted September 15, 2012 I've seen a truck KA24e with 423,000 miles on the clock ... lots of oil saver receipts and such in the glovebox though lol I about shit myself when I saw it ^^^ Quote Link to comment
yankabilly Posted September 16, 2012 Report Share Posted September 16, 2012 it all depends on your skill and drive Quote Link to comment
BoostinBen Posted September 25, 2012 Report Share Posted September 25, 2012 Any swap is going to cost you a bit outa pocket to do it right (there is nothing worse or sometimes more dangerous than a half ass swap) .. when you upgrade there are lots of things to take into concideration, proper fabrication to fit the motor and driveline, wiring, cooling, linkage .. on and on.. then upgrading whatever else necessary in the car to keep it safe with the additional power .. ie brakes, steering, suspension.. I am on board with the guys suggesting the ka24de, one of the more cost effective swaps because of the parts avalibility and the fact that every other 240 fan is dropping them out for SR's or LS1's so you can find them for next to nothing used. .. I wouldnt advise against an sr20det either you can keep it cheap just as long as you are keeping it tame and the motor stock.. They are crazy reliable as well and parts easy to find .. just a bit more expensive. The big $$ comes in when you start upgrading the crap outa things.. which when you have one of these motors that have huge industry support as far as upgrade parts is hard to stay away from ... beleive me .... I know Quote Link to comment
rayven14 Posted September 25, 2012 Report Share Posted September 25, 2012 +1 for what Ben said. Im simply doing a fuel injected L20 and thats kickin my butt and while its affordable I probably could have swapped in the KA and been ahead of the game. Although I can say that what I've learned along the way is priceless. Quote Link to comment
