My 620 with Blue L.E.d's Outside and inside
72MAMBA
  • Replies 26
there isnt a state in the US that doesn't outlaw blue lights on a car/truck, you can only run then when the car is not running(for shows). just an FYI
Not 100% true. In most states it's legal as long as the bulb itself isn't visible and/or flashing.
In fact, I have a legal emergency light permit on my truck that would allow me to run emergency lights on my truck legally on road.
Cops hate it since it's legal.
have you ever driven down the road with the blue lights on MM?
But he's in Cali, MM.
Nothing flies there.
This is true. Fucking californians
Me, no. But I have a friend that's registered for road side assistance that's uses them occasionally when helping with an accident.
I don't do the whole 'bright flashing lights' thing. Permits just a cool sticker :thumbup:
California vehicle code is draconian and convoluted, but the section that defines who can use blue lights is listed here under Division 12, Chapter 2, Article 7, sections 25250-25282
An authorized emergency vehicle used by a peace officer, as
defined in Section 830.1 of, subdivision (a), (b ), (c ), (d), (e),
(f), (g), or (i) of Section 830.2 of, subdivision (b ) of Section
830.31 of, subdivision (a) or (b ) of Section 830.32 of, Section
830.33 of, subdivision (a) of Section 830.36 of, subdivision (a) of
Section 830.4 of, or Section 830.6 of, the Penal Code, in the
performance of the peace officer's duties, may, in addition, display
a steady or flashing blue warning light visible from the front,
sides, or rear of the vehicle.
Section 25950 lays out what colors of lamps and reflectors are required or permitted for vehicles.
25950. This section applies to the color of lamps and to any reflector exhibiting or reflecting perceptible light of 0.05 candela or more per foot-candle of incident illumination. Unless provided otherwise, the color of lamps and reflectors upon a vehicle shall be as follows:
(a) The emitted light from all lamps and the reflected light from all reflectors, visible from in front of a vehicle, shall be white or yellow, except as follows:
(1) Rear side marker lamps required by Section 25100 may show red to the front.
(2) The color of foglamps described in Section 24403 may be in the color spectrum from white to yellow.
(3) An illuminating device, as permitted under Section 24255, shall emit radiation predominantly in the infrared region of the electromagnetic spectrum. Any incidental visible light projecting to the front of the vehicle shall be predominantly yellow to white. Any incidental visible light projecting to the rear of the vehicle shall be predominantly red. Any incidental visible light from an illuminating device, as permitted under Section 24255, shall not resemble any other required or permitted lighting device or official traffic control device.
(b ) The emitted light from all lamps and the reflected light from all reflectors, visible from the rear of a vehicle, shall be red except as follows:
(1) Stoplamps on vehicles manufactured before January 1, 1979, may show yellow to the rear.
(2) Turn signal lamps may show yellow to the rear.
(3) Front side marker lamps required by Section 25100 may show yellow to the rear.
(4) Backup lamps shall show white to the rear.
(5) The rearward facing portion of a front-mounted double-faced turn signal lamp may show amber to the rear while the headlamps or parking lamps are lighted, if the intensity of the light emitted is not greater than the parking lamps and the turn signal function is not impaired.
(6) A reflector meeting the requirements of and installed in accordance with Section 24611 shall be red or white, or both.
(c ) All lamps and reflectors visible from the front, sides, or rear of a vehicle, except headlamps, may have any unlighted color, provided the emitted light from all lamps or reflected light from all reflectors complies with the required color. Except for backup lamps, the entire effective projected luminous area of lamps visible from the rear or mounted on the sides near the rear of a vehicle shall be covered by an inner lens of the required color when the unlighted color differs from the required emitted light color. Taillamps, stoplamps, and turn signal lamps that are visible to the rear may be white when unlighted on vehicles manufactured before January 1, 1974.
Fun stuff... Btw, your blue lights are illegal to use on public roads. However, like somebody mentioned, you can leave them installed on your truck and use them as long as you're not parked on a public road or right of way.
Were i live Cops got bigger things to worry about than blue lights on a 72 datsun. i use them when im parked of course . i just added some red ones to pics coming up soon.. i will also put more pics up of my project .. door panels,welded hood ,engine work, custom tailgate,new tailights after they hit me ..check ou my pics to see my leds under the hood
