xxmass Posted August 8, 2012 Report Share Posted August 8, 2012 28 guage sheet metal is sold at home depot in 12"x12" it may feel flimsy, but when cut to this size and with the bends it feels just right. also at this guage it can be cut with hand shears and bent pretty much by hand and light hammer use. i also used a bench vise. i mocked up the shield with repurposed 6pack cardboard. the mounting holes and bolts are from the air cleaner bracket. the holes are 1/4" drill bit with 36mm center to center here completed in metal and formed and installed 3 Quote Link to comment
metalmonkey47 Posted August 9, 2012 Report Share Posted August 9, 2012 very nice. I may do this with some spare metal. Is that galvanized steel? Quote Link to comment
really_drunk Posted August 9, 2012 Report Share Posted August 9, 2012 sweet! i had to flip mine 180 to get timing right and was worried about it getting too hot! will try this for sure! Quote Link to comment
xxmass Posted August 9, 2012 Author Report Share Posted August 9, 2012 it is galvanized. Quote Link to comment
datzenmike Posted August 9, 2012 Report Share Posted August 9, 2012 Or drop the oil pump rotate the drive spindle about 90 degrees. Put the dizzy back in turned 90 and the vacuum advance will be toward the rad, the matchbox will be down at 6 o'clock and cooled by the rad air. 2 Quote Link to comment
Eagle_Adam Posted August 9, 2012 Report Share Posted August 9, 2012 but but but, engine bling mike :D Quote Link to comment
datzenmike Posted August 9, 2012 Report Share Posted August 9, 2012 That IS true. Very Ratsun. Quote Link to comment
I'm BLUE Posted August 9, 2012 Report Share Posted August 9, 2012 A great idea regardless Thanks for sharing Quote Link to comment
