Dawa Posted July 10, 2012 Report Share Posted July 10, 2012 so the transmission i had in storage that was supposedly 5 speed is not (verified by the king rat.) therefore, looking for a 5 speed transmission from a 620 or Z. thanks previous titles: wtb 73 620 parts: dogleg wtb 73 620 disc brake conversion bracketS title says it all. i need fronts and rears.and perhaps any applicable parts you wanna sellfor cheap. thanks boys. sourced a set of front & rear brackets & instead of creating more WTB threads, ill just edit this onewtb dogleg transmission that i can drop directly into my 73 620.so im looking for something that isnt of 'unknown status.' hopefully someone has a trans that they can vouch for. thanks all Link to comment
Dawa Posted July 11, 2012 Author Report Share Posted July 11, 2012 bought fronts from beebani. will probably buy rears from him as well within a month if i dont get any leads here. Link to comment
]2eDeYe Posted July 11, 2012 Report Share Posted July 11, 2012 Beebani is going to be your best bet for the rears as well. :) Link to comment
Dawa Posted July 11, 2012 Author Report Share Posted July 11, 2012 i agree, unless someone already had a set from him that they were parting with :) Link to comment
Dawa Posted July 11, 2012 Author Report Share Posted July 11, 2012 front and rear brackets sourced and bought. thank you to Beebani and str8_69. to keep the forum less cluttered, im going to change thread title to reflect my other wtbs Link to comment
datzenmike Posted July 12, 2012 Report Share Posted July 12, 2012 wtb dogleg transmission that i can drop directly into my 73 620. so im looking for something that isnt of 'unknown status.' hopefully someone has a trans that they can vouch for. thanks all Well it could maybe easier to find a short 2wd 720 5 speed and swap an L series front case onto it. That will fit the 521 so, sure to fit the early 620. Much stronger and newer transmission. Link to comment
Dawa Posted July 12, 2012 Author Report Share Posted July 12, 2012 i have heard of going that route. it was a little more work than i wanted to do but id be willing to go either route Link to comment
crackerjack69 Posted July 12, 2012 Report Share Posted July 12, 2012 I've got a good dogleg fs, but shipping would suck. Link to comment
datsunaholic Posted July 12, 2012 Report Share Posted July 12, 2012 Dogleg isn't a straight drop in either. Mounts get a little funny, though it's an easier swap than into a 510. But It's a heck of a lot easier to use a real truck 5-speed and get the matching mount and front driveshaft. Link to comment
Dawa Posted July 12, 2012 Author Report Share Posted July 12, 2012 ^ ah i see. this guy i met who had 6 620s at one time told me it was the one 5 speed that would easily drop it. cjack, i can understand shipping something heavy like that would be expenso. but humor me, give me an estimate. Link to comment
datzenmike Posted July 12, 2012 Report Share Posted July 12, 2012 The early 620 used a short 4 speed similar to the 510 so a short dogleg will fit with some reasonable mods. The only advantage is you don't have to shorten the driveshaft. A longer '74 or newer 4 speed or 5 speed uses a shorter driveshaft so if you can find one and the rear transmission mount from a 620 go that route. Link to comment
datsunaholic Posted July 12, 2012 Report Share Posted July 12, 2012 It's easy in that you can use your existing driveshaft. It's just that the mount is in a different place. Fortunately the 620 came with mount locations for both long and short transmission mount pads even in '73 (the dogleg is in between as far as the mount location) so you just have to figure you where to mount and how to space it. The bad part about the dogleg is it's a LOT weaker, harder to find, and usually more expensive than the truck or 280Z/ZX 5-speeds that are quite a bit stronger. I have a dogleg in my '74, it's on its last legs due to my hauling a lot of heavy loads. Link to comment
datzenmike Posted July 12, 2012 Report Share Posted July 12, 2012 Right. The 620 has the same 4 and 5 speeds used in the 6 cylinder Z cars. Link to comment
Dawa Posted July 12, 2012 Author Report Share Posted July 12, 2012 alright, you guys sold me! 'preciate it! Link to comment
Dawa Posted July 12, 2012 Author Report Share Posted July 12, 2012 i have a 5 speed in storage that i was gonna use on my 280z when i had it... hmm my wheels are turning, i just have to find the right thread to know how to make it work because i am so very confused right now aha Link to comment
datsunaholic Posted July 12, 2012 Report Share Posted July 12, 2012 If you have the transmission, you have the expensive part. Now, you need the front driveshaft (the short one) from any '74-79 620 and the '74-79 620-specific transmission mount. Getting the crossmember wouldn't be a bad idea too, because otherwise you might have to drill holes, with the later one it will be correct. You'll also need the speedometer cable, as yours will be short (but it would have been short on a dogleg too if I recall correctly). You will also want the floor plate (for the shifter) of the later truck, though modding what you have is possible. You should be able to get all of those at Ecology or whatever that massive U-pull junkyard chain down there is called nowadays. Link to comment
Dawa Posted July 13, 2012 Author Report Share Posted July 13, 2012 woohoo thanks a lot Link to comment
Dawa Posted October 17, 2012 Author Report Share Posted October 17, 2012 modded thread, looking for a 5 speed trans Link to comment
datzenmike Posted October 17, 2012 Report Share Posted October 17, 2012 i have a 5 speed in storage that i was gonna use on my 280z when i had it... hmm my wheels are turning, i just have to find the right thread to know how to make it work because i am so very confused right now aha You said you had one? Link to comment
Dawa Posted October 17, 2012 Author Report Share Posted October 17, 2012 i do and i sent you photos via private message to ID it and you said it's a 4 speed. Link to comment
datzenmike Posted October 17, 2012 Report Share Posted October 17, 2012 Oh yeah. So many members so many p/ms I forget. Link to comment
Seeker > 620 KC Posted November 10, 2012 Report Share Posted November 10, 2012 As of this A.M.I just noticed there is a black 720 2WD (Datsun on tailgate) with 5 speed still intact in the Oceanside (north San Diego County) Ecology wrecking yard. It has already been there for 3-4 weeks. Could get pulled out soon. The door tag says 7 or 8/79. Shifter is still in it. I was able to shift it in/out of gears. I asked at the cashier, regular price is $130. I'm certain...but I think the rest of the drive line & cross member was still in it too. Link to comment
datzenmike Posted November 10, 2012 Report Share Posted November 10, 2012 Has to be an '80 with the L20B. Last year an L20B was put in any vehicle. (well in N Am) Link to comment
Seeker > 620 KC Posted November 11, 2012 Report Share Posted November 11, 2012 Rats! Wrong again? And I didn't check the engine size or take a photo either. My bad. Sorry. I swear this one had the newer 720 body style (not the bullet side) and thought for sure I read the tag as having one digit before the year 79. I'll check it again next Saturday and take pics. Damn aging eyes. Link to comment
datzenmike Posted November 11, 2012 Report Share Posted November 11, 2012 '80 720 is what I meant. It could have a build date as early as 06 '79 and still be an '80 model year. Only the '80 model year had the L20B motor, so the transmission is a bolt onto any other L series motor. Link to comment
