jrock4224 Posted June 24, 2012 Report Share Posted June 24, 2012 The tranny mount I have has two close bolts holes and wot fit down in the crossmember at all.... The holes on the cross emeber don't match up with mount so I m missing something? on way home, to post pics ..... The tranny is a truck620 or wagon tranny and a pic is in build thread project 71 goon........ This tranny was never in my goon and it was a four speed I believe so do I need a diff rear mount to attach to the crossmember Quote Link to comment
LenRobertson Posted June 25, 2012 Report Share Posted June 25, 2012 Not sure it is the same on a goon, but with a 510 sedan, the tranny Xmember needs to be spaced down about an inch, and the position where the rubber mount bolts to it moved slightly fore or aft (can't remember which). The distance from the front of the tranny to where to rubber mount bolts is slightly different from the stock 510 4-speed and any of the 5-speeds. At least this is what I remember. I went out to my pile of parts to take a couple of measurements, but the pile is overwhelming, and the trannys are on the bottom. Hoping someone else will confirm what I'm remembering. Going over to read all your build thread. I got as far as you cracking your skull when you went to get the goon. My wife's horse barn had a spot like that going into a stall. 2X10 across the opening about 5' 10" height. I'm a bit over 6' height. Hit that board at a fast walk made a big thump. Len Quote Link to comment
Sealik Posted June 25, 2012 Report Share Posted June 25, 2012 Not sure it is the same on a goon, but with a 510 sedan, the tranny Xmember needs to be spaced down about an inch, and the position where the rubber mount bolts to it moved slightly fore or aft (can't remember which). The distance from the front of the tranny to where to rubber mount bolts is slightly different from the stock 510 4-speed and any of the 5-speeds. At least this is what I remember. I went out to my pile of parts to take a couple of measurements, but the pile is overwhelming, and the trannys are on the bottom. Hoping someone else will confirm what I'm remembering. Len Dime Quarterly https://docs.google....jQ4MjMzZWE0MjRh Just did it for my 510...5 speed trannie with 4 speed mounts Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 Not sure it is the same on a goon, but with a 510 sedan, the tranny Xmember needs to be spaced down about an inch, and the position where the rubber mount bolts to it moved slightly fore or aft (can't remember which). The distance from the front of the tranny to where to rubber mount bolts is slightly different from the stock 510 4-speed and any of the 5-speeds. At least this is what I remember. I went out to my pile of parts to take a couple of measurements, but the pile is overwhelming, and the trannys are on the bottom. Hoping someone else will confirm what I'm remembering. Going over to read all your build thread. I got as far as you cracking your skull when you went to get the goon. My wife's horse barn had a spot like that going into a stall. 2X10 across the opening about 5' 10" height. I'm a bit over 6' height. Hit that board at a fast walk made a big thump. Len i got some 1x3 rectangular tubing for that but the mount wont go in the crossmember... to be honest i don't even know where this tranny mount came from lemme get the pics on here to help... Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 yeah in the pic from under see your mount has a wide spread bolt pattern where they bolt to cross member ... the one i have the bolt holes in the bottom are about two inches apart ... i assume off the tranny that came our of the car....and the five speed is a truck or wagon one we had...its a 31" 5sp..the problem is the urethane mount ...its the wrong part... cause even with my spacers the mount wont seat down in cross member and even if it did no bolt holes correspond... Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 my spacers are like i said ....1x3 sqauare tube 6" long capped at the ends.... Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 wow ok... never used the dime quarterlly before ...should read the link before all my finger cramps and photobucket shinanagans....looks like i need a four speed isolator ... i can probably buy new at a ports store... Quote Link to comment
Sealik Posted June 25, 2012 Report Share Posted June 25, 2012 You need the narrow 510 isolator/trannie mount to fit into 510 cross member Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 parts store should have .... narrower would be nicer this one doens't nor wouldn't fit in there ...i assume that would be a four speed isolator? edit this iso came off the tranny which we thought came from a wagon but coulda come from anywhere...pretty sure this tranny came from izzo ... which means it could have pantys for a pic up screen... Quote Link to comment
Sealik Posted June 25, 2012 Report Share Posted June 25, 2012 parts store should have .... narrower would be nicer this one doens't nor wouldn't fit in there ...i assume that would be a four speed isolator? Correct edit this iso came off the tranny which we thought came from a wagon but coulda come from anywhere...pretty sure this tranny came from izzo ... which means it could have pantys for a pic up screen... Pantys are good..no socializing though Quote Link to comment
jrock4224 Posted June 25, 2012 Author Report Share Posted June 25, 2012 hahahah true... didnt find it on rock auto...its wierd they list no tranny mount any year..everything else for a transmission not the mount though Quote Link to comment
jrock4224 Posted November 8, 2012 Author Report Share Posted November 8, 2012 You need the narrow 510 isolator/trannie mount to fit into 510 cross member having no luck sourcing this any help would be appreciated... Quote Link to comment
ggzilla Posted November 8, 2012 Report Share Posted November 8, 2012 RockAuto transmission mount Quote Link to comment
datsunaholic Posted November 8, 2012 Report Share Posted November 8, 2012 That's the narrow type used on trucks just like the one he has, he needs the wider pattern one for a 510 crossmember. Quote Link to comment
ggzilla Posted November 9, 2012 Report Share Posted November 9, 2012 Yep, RockAuto sells transmission mounts. Quote Link to comment
Creepy Cruiser Posted November 9, 2012 Report Share Posted November 9, 2012 They have them in Mexico, lol. (And at a fair price even.) http://www.ebay.com/...=item564df251b2 Quote Link to comment
jrock4224 Posted November 10, 2012 Author Report Share Posted November 10, 2012 i think creepy hooked it up .... Quote Link to comment
