Zeusimo Posted June 17, 2012 Report Share Posted June 17, 2012 So I Installed A Rebuilt 75 710 L20b Carb, Plugged The Holes, Removed Idle Cam, Choke, And Anti-Diesel Valve. Set Timing To 12BTDC, Adjusted Valves, New Kyosan Fuel Pump, New Gapped Plugs 0.030, And Points 0.020, Dwell No Clue... Bled Air Out Of Cooling System, Removed Secondary Points, Rebuilt Top-End U67 Peanut U20 Cam Everything On Motor Lines Upto TDC 11:28, Cam/V-Notch, 2 On Sprocket, New Beck/Arnley Chain So Car Starts Up Fine And Doesn't Missfire Carb Squirts Strong Gas When Off For Only 2-3 Pumps When Off It Is Very Responsive When Giving It Gas But It Doesn't Idle Right Even When Hot Goes From 800-1200 Up And Down Every 5 Secs? Not Sure If This Is Right I Did Have A Holley On It Before.. And It Ran GOOD But It Seems Too Much For Even A V8? I Much Rather Have A Hitachi/Weber I Still Need To Find/Install PCV Hose To Intake Will L20b Carb Not Work With L18? Video: http://www.youtube.com/watch?v=UMANgiC1CeQ Quote Link to comment
datzenmike Posted June 17, 2012 Report Share Posted June 17, 2012 Looks like the choke wire and the idle cut solenoid not wired up. Other than that maybe a vacuum leak. Grab the carb and try to twist it. If it moves it may not be mounted tightly or the internal screws between the base and the body are loose. Quote Link to comment
Zeusimo Posted June 17, 2012 Author Report Share Posted June 17, 2012 Yeah I Removed The Choke And Pin From Valve If I Hook Them Up It Will Just Die Quote Link to comment
bananahamuck Posted June 17, 2012 Report Share Posted June 17, 2012 The wires hanging need to be hooked up ,,,The one that goes to the back of the carb to that big hex bolt thing ...you can see at :27 on the top right side of carb ,,helps control the idle .. Quote Link to comment
bonvo Posted June 17, 2012 Report Share Posted June 17, 2012 make sure that the screws in the base of the carb are tight and are not stripped my stock hitatchi was like that the base screw closest to the throttle linkage was stripped and would never tighten so as i worked the throttle the carb would actually seperate creating a huge vacuum leak Quote Link to comment
Zeusimo Posted June 17, 2012 Author Report Share Posted June 17, 2012 @Bonvo Same Thing With That Screw, Didn't Even Idle Before I Had To Cut It Down Almost Three Threads To Get It To Tighten Also Used Two Gaskets, One Before And After The 1/16" Spacer Plugged The Vaccum Lines With Tighter Hoses And It Helped Alittle Bit But Tommoz I Will Try To Get A Torque Wrench And Retorque Intake/Exhaust Yeah... BTW What Is Intake/Exhaust Torque Spec? Quote Link to comment
ggzilla Posted June 17, 2012 Report Share Posted June 17, 2012 9 to 11 ft-lbs. They are just small studs. Quote Link to comment
Zeusimo Posted June 17, 2012 Author Report Share Posted June 17, 2012 So I Retorqued Intake/Exhaust Checked For Leaks W/ Starting Fluid Squirted A Ton Of Carb Cleaner In The Carb When Runing Now Idles Reved A Few Times Idled And Died After A Min Cuz I Ran Out Of Gas Gonna Go Get Some More Gas But I THINK Everything Is Ok Quote Link to comment
Zeusimo Posted June 18, 2012 Author Report Share Posted June 18, 2012 Yeah!! Got It Going :D Needs Abit Of Fine Tuning And Done I Guess It Was So Dirty I Had To Use 3 Cans Of Carb Cleaner http://www.youtube.com/watch?v=odp5AYRhBQU Quote Link to comment
