ehime Posted May 21, 2012 Report Share Posted May 21, 2012 So guys I just got all my lights together and wanted some opinions, I'm not sure if the colors are a little gaudy/iffy so I thought I'd ask "the masses" what they think, First up are a set of Koito ambers for headlights, the highs would probably be clears, and my fogs are a set of IKI 2005 (circa 70's?) anyway here's some pics, they fogs are kinda yellow, the highs are clear, and the heads are amber. What do you guys think? Quote Link to comment
banzai510(hainz) Posted May 21, 2012 Report Share Posted May 21, 2012 whites are best for the outlights H4s even high beams I have my highs yellow but mostly for looks as a rarely use my highs anyway but have H1 Hella 500s that light up the signs far away. 50amper alternator. yellow you can see in the fog betteror at least see the car that has the yel lights approching 1 Quote Link to comment
Laecaon Posted May 21, 2012 Report Share Posted May 21, 2012 Um, amber lows seems silly. Are you sure they are even low beams and not just fog lights? Using fog lights as head lights is wrong, blinding to others, and well they dont offer much down road vision. Also at least here in Oregon, it is technically illegal to have your fogs on anywhere you cant have your highbeams on as well. Quote Link to comment
ehime Posted May 22, 2012 Author Report Share Posted May 22, 2012 pretty sure they aren't? Course I doubt I'll be doing a lot of nighttime driving. Quote Link to comment
bonvo Posted May 22, 2012 Report Share Posted May 22, 2012 those are for the inners they only have 2 prongs why run them on the outside they wouldnt be bright enough and just wouldnt look right in my opinion Quote Link to comment
zerow Posted May 24, 2012 Report Share Posted May 24, 2012 those are for the inners they only have 2 prongs why run them on the outside they wouldnt be bright enough and just wouldnt look right in my opinion Bonvo is right - two prongs mean inners only...unless you rewire and relay for them to become outers. You will lose the functionality of the low/high combination if you run them on the outsides. Quote Link to comment
