sdsurf Posted May 8, 2008 Report Share Posted May 8, 2008 Any tips, luck on removing these from the flange to the downpipe? One came free, the other two are sheared off. Quote Link to comment
banzai510(hainz) Posted May 8, 2008 Report Share Posted May 8, 2008 drill them out.(yeah what a pain)I havent done it myself, if the y pipe is already sepatrated I would pull the manifold and take it in crap at this point you might just pull the hole exhaust manifold out and take it to a shop to put new studs in(maybe stainless) and use high temp antiseize compound on there. then maybe at this point just get a short tube header But its up to you. Quote Link to comment
]2eDeYe Posted May 8, 2008 Report Share Posted May 8, 2008 Hit the center of the broken bolt with a center punch. Drill and tap for helicoil inserts. Edit: Hainz beat me to it. :P Quote Link to comment
banzai510(hainz) Posted May 8, 2008 Report Share Posted May 8, 2008 just grind it and put a C clamp on there to hold it together!!!!!!!!! it worked for my dads Ford 150!!!!!!!!!!! Quote Link to comment
datzenmike Posted May 8, 2008 Report Share Posted May 8, 2008 If you drill and use an easy out, heat the metal around the broken stud untill red hot and it will twist out much easier. Best to take it off for this. Of course once off, it's even easier to put another one on. Quote Link to comment
Llittle_Llama Posted May 8, 2008 Report Share Posted May 8, 2008 as everyone else said, i would also remove and helicoil. just get a nice set of easy outs from sears though so you can take them back if they break :D Quote Link to comment
sdsurf Posted May 9, 2008 Author Report Share Posted May 9, 2008 Manifold is out and sitting on my bench. Thinking of grinding flush, drilling and heating out. This it? Hainz?, mike? Quote Link to comment
datzenmike Posted May 9, 2008 Report Share Posted May 9, 2008 I've removed bolts that were just enough to barely get vice grips on. Use the largest easy out you can get into the drilled bolt. Heat the manifold all around the bolt until red or orange. This will expand the metal and believe it or not makes the hole bigger and much easier to twist the bolt out. It will screech like hell when it comes out. Quote Link to comment
OL YELLER Posted May 9, 2008 Report Share Posted May 9, 2008 . It will screech like hell when it comes out. Uh Huh.......That is what she said Quote Link to comment
Llittle_Llama Posted May 9, 2008 Report Share Posted May 9, 2008 also pb blaster, i would SOAK that shit....anyone else? Quote Link to comment
