rome11six Posted April 30, 2012 Report Share Posted April 30, 2012 So i picked up my 73 datsun 620 for $350 and she looked like this about three months after i got it the clutch started slipping so i just decided to drop a new engine in it since the compression sucked, and it just so happened i had a freshly rebuilt ka24de laying around. the last month iv been slowly getting stuff together like fuel pump, fuel pressure regulator, custom drive shaft, new center link and reversing the tapper, fan, and other tid bit stuff. after last weekend i got the motor and tranny mounted and most of the wiring done and now all i need is the drive shaft and the fuel line and pump to get it running. This is after last weekend, hoping to get it running good in time for canby! Quote Link to comment
]2eDeYe Posted May 1, 2012 Report Share Posted May 1, 2012 Looks good! :thumbup: Quote Link to comment
K_trip Posted May 1, 2012 Report Share Posted May 1, 2012 2eDeYe' timestamp='1335882791' post='678965']Looks good! :thumbup: +1 Quote Link to comment
southern620 Posted May 1, 2012 Report Share Posted May 1, 2012 The KA looks right at home under the hood of the 620. Looks good man. Quote Link to comment
rome11six Posted May 1, 2012 Author Report Share Posted May 1, 2012 thanks guys cant wait to get it running! Quote Link to comment
mrbigtanker Posted May 2, 2012 Report Share Posted May 2, 2012 Keep it up looking good.I want to hear it start. Quote Link to comment
rome11six Posted May 17, 2012 Author Report Share Posted May 17, 2012 Well quick update i just picked up the cut and welded drive shaft from the shop and got it in, fits good just got to make a couple tweaks. now all i need is the fuel pump that ill order this Friday. Quote Link to comment
southern620 Posted May 17, 2012 Report Share Posted May 17, 2012 How many inches you have to shorten it? Quote Link to comment
rome11six Posted May 17, 2012 Author Report Share Posted May 17, 2012 i don't know exact but it wasn't much more than 1 inch maybe less. i had the shop match up the stock 4 speed front shaft length to the 240sx auto front shaft. i would have just used the 240sx front shaft but the spline didn't match. Quote Link to comment
rome11six Posted July 24, 2012 Author Report Share Posted July 24, 2012 ok i finally got everything in and now its running.... ill post pics and a vid latter this week but i do have a problem with the clutch slave it hits the gusset! iv looked at some pics on here and i looks like some people dont have them on, i heard its bad not to have them cause it could put stress on the input shaft!?! any input would help thanks ill post a pic of this problem tomorrow. Quote Link to comment
]2eDeYe Posted July 24, 2012 Report Share Posted July 24, 2012 Not sure which slave cylinder you are using. I had to use the truck one, the car one hit the torsion bar. Can you could clearance the gusset with a grinder? Quote Link to comment
rome11six Posted July 24, 2012 Author Report Share Posted July 24, 2012 It's bad quality but it's the truck slave I'm using and as far as cutting it I never though of that good idea! And this is the motor in running condition I moved it today about a foot then realized I forgot gear oil in the tranny, I also have to make a chain shifter for it since the seat is in the way ( forgot what issue its out of but project cars chain link shifter for the Datsun) Quote Link to comment
]2eDeYe Posted July 25, 2012 Report Share Posted July 25, 2012 Man, these look good in the 620 engine bay :D Quote Link to comment
k-autic Posted July 25, 2012 Report Share Posted July 25, 2012 Great buy! Looking hella good would love to see quick take off vids Quote Link to comment
rome11six Posted October 1, 2012 Author Report Share Posted October 1, 2012 ok so iv searched and havent found a answer.... i have 4.6 rear end gears and i want to swap out for 3.89 out of the 720 can that handle up to 300ft tq? also a lsd would be nice but not necessary. :thumbup: Quote Link to comment
rome11six Posted October 3, 2012 Author Report Share Posted October 3, 2012 Havent been on in a while got caught up in life..... but i got the motor running good and most of the little things out of the way and i picked these rims up today for 20 bucks :thumbup: Then i cleaned them...... Then i got some free rubber........ and mounted them! Doesnt look to bad there 15X7 im going to get 15x10 and put them on the rear and the 7's on the front....... and paint them black! Quote Link to comment
rome11six Posted October 3, 2012 Author Report Share Posted October 3, 2012 It finally runs good..... although i did call it intercooler piping.... lmao been a long day! http://www.youtube.com/watch?v=n5WU_6Uz-CU&feature=youtu.be 1 Quote Link to comment
Wide14u Posted October 3, 2012 Report Share Posted October 3, 2012 I like this sounds good Quote Link to comment
rome11six Posted October 3, 2012 Author Report Share Posted October 3, 2012 thanks its a tad raspy for my liking but it will do for now till i do the next motor swap.... tehehe Quote Link to comment
]2eDeYe Posted October 3, 2012 Report Share Posted October 3, 2012 Nice work :thumbup: Quote Link to comment
datzenmike Posted October 3, 2012 Report Share Posted October 3, 2012 The H-190 came in 3.365, 3.545, 3.70, 3.889, 4.11, 4.375, 4.625 and 4.875 (maybe more) and are good for just under 300 ft. lbs. torque rating. More than enough for a DE. LSDs are only now available after market. Quote Link to comment
rome11six Posted December 3, 2012 Author Report Share Posted December 3, 2012 Ok so I lost one of the torsion bar bolts and was wondering if they are specific to our trucks or if I can pick one up at the part store? Quote Link to comment
]2eDeYe Posted December 4, 2012 Report Share Posted December 4, 2012 Should be able to pick one up at the store. You will need the anchor piece that the bolt goes through that holds the torsion arm. Quote Link to comment
rome11six Posted December 5, 2012 Author Report Share Posted December 5, 2012 Luckily I found them. Quote Link to comment
71kat510 Posted December 6, 2012 Report Share Posted December 6, 2012 The H-190 came in 3.365, 3.545, 3.70, 3.889, 4.11, 4.375, 4.625 and 4.875 (maybe more) and are good for just under 300 ft. lbs. torque rating. More than enough for a DE. LSDs are only now available after market. a stock 240sx rear end ratio is a 4.08 which from my experience is a good setup with the engine until you do any highway driving 75mph is about 3k rpms which isnt bad with a stock exhaust but modified exhaust gets annoying and also keep in mind your speedo will be off and im sure its off already Quote Link to comment
