brodster Posted April 15, 2012 Report Share Posted April 15, 2012 So I finally got my hack job of an oilpan done using pieces from a Z22 rear-sump and a Z20e front-sump. I just sand-blasted it to clean it up, and now I have to paint it. I did a bunch of google searching on painting oilpans, and it seems there is a lack of consensus on how to paint them--especially the inside. Many people say to leave the inside bare because there is oil in there anyways. Plus the risk of paint chipping off and clogging the oil passages is risky. Makes sense. However others have claimed that IF ANY water gets in the oil system, it can be highly corrosive at certain temperatures. I guess this is just a big risk assessment. Perhaps the risk of rusting out the inside of an oilpan is low and doesn't justify painting it. What would you guys with experience in engine rebuilding recommend? Thanks Quote Link to comment
DAT510 Posted April 15, 2012 Report Share Posted April 15, 2012 Oil pans are replaceable... I left mine bare after a sandblast, then painted the outside with black engine enamel Quote Link to comment
Trophy24 Posted April 15, 2012 Report Share Posted April 15, 2012 The stuff I see is powder coated inside and out. I would not worry about the inside. Just make it look good with some engine paint. Quote Link to comment
hobbes_the_cat Posted April 15, 2012 Report Share Posted April 15, 2012 I have seen a product called Gyptol ( i think that's how you spell it) that is used to paint the inside of blocks to promote heat transfer and speeding up the oils trip back to the pan. I don't know if it is good to use in oil pans too but it might be worth looking into. if it wont flake off of the block why would it flake off the inside of the pan? Otherwise I would leave it bare. EDIT OOps! I just saw that you already mentioned Gyptol. duh! By the way that pan looks good! Quote Link to comment
TENDRIL Posted April 15, 2012 Report Share Posted April 15, 2012 i say leave the inside bare, fact is if your worried about water corrosion in your oil pan i would think there are far bigger issues to deal with such as how water is getting in there, or why. the only way water (dangerous amount) should be able to get in there is a blown motor, yes there are very tiny and i mean tiny amounts that get in there past the pistons from the atmosphere through your intake but 99.9% is pushed right out the exaust thus you have a dew drip in the morning super heated than super cooled kinda like a whiskey still dont worry about the inside brother :thumbup: Quote Link to comment
brodster Posted April 15, 2012 Author Report Share Posted April 15, 2012 Alright then, I will leave it bare on the inside and see how that works out. I actually have some extra POR-15 so I might use that on the outside instead of engine paint. Might be a bit more tough. Quote Link to comment
DAT510 Posted April 15, 2012 Report Share Posted April 15, 2012 Oh yeah, spray (or roll) something like herculiner or Rhino lining on the pan if you're going to slam your dime Quote Link to comment
datzenmike Posted April 15, 2012 Report Share Posted April 15, 2012 Bare inside, Nissan doesn't coat it that I know of. High temp paint not needed, won't get that hot on outside. Quote Link to comment
Just Joel Posted April 24, 2012 Report Share Posted April 24, 2012 Powder coat... Quote Link to comment
Spades Posted April 30, 2012 Report Share Posted April 30, 2012 do not paint the inside...engine doesn't play nice with paint. There should not be major condensation or water in the oil pan, if there is, more than paint is required. The paint might last a while...but eventually it will flake off and clog up the pickup tube and oil passages. Paint the outside with a tough engine paint, or as someone else suggested, if you ride low or want a permanent non chip paint, bed liner that sucker. Quote Link to comment
