Dropped 620 sitting on bumpstops
chebetio510
  • Replies 56
520/521/620 and 720 leave springs are the same dimensions (1,200mm long and 60mm wide) just differing thicknesses and numbers of leaves to vary the spring rate. A Hardbody rear might fit but is wider, around 60" wms to wms, than a 720 which is wider than a 620.
Thanks to Zeusimo for the link to those bump stops. He said he did not have to tap his but he did have to trim down the stud. His is a ball-joint truck, mine is a kingpin truck. Just another difference between the two.
The aforementioned bump stops.
Tappy, tap, tap 3/8-16
Screwed in
Locked down
Passenger side.
Shocks should be in this week. Got some KYB's and I'll be checking the parts store for the rest of the bushings up front. smile.gif
@redeye  i just noticed you have adjustable outer tie rod ends.. what year is that from? on my 74 they are solid and only adjustment for alignment is at the center link but with your set up looks like u can adjust each wheel
