Nano's k-autic 620
k-autic
  • Replies 224
My idler was a breeze but the pitman arm.. That's no joke, I gave up on it.
Did you use any heat, I was afraid too, or did you just go cave man 101 on it & beat the hell out of it.?
Taking the idler arm nd pitman was a bitch but I got them!
I used caveman 101 took a while but got it also I rented the pitman arm fork from o'rilleys for 10 bucks! It helped when I stomped my 230 lbs on the fork
:) hahaha right on. apparently I just need to man up & give it a beat down.
what the are the sparks
The sparks were coming from the starter, the positive was a lil loose on it but I tightened it up.
Wow, you got it running already. Impressive
Thanks it was a test to make sure the wiring was correct and that it fired up, but she's alive! But it dies like few seconds later I need to plug n connect all the vacuum stuff and button few things up still.
Keep at it it took me bout 2 hours of jumping on it and with the fork on it to get it just don't give up.
i think this truck is gonna be fast as hell..
i wanna go for a ride already!
I want to go for a ride on yours.
  • 3 weeks later...
que perro esta quedando tu datsun man que bueno que mas y mas datsun estan resurgiendo por doquier y unos rinsitos de titan y uff quedara con madres ese datsunsito en hora buena felicidades por tan buen proyect  :thumbup:
damn son nice... are you going to canby? :)
I'm trying to get it to idle it used to then I took it to get the down pipe made turned it on it felt fishy then drove it bout a block ant it stalled after that it won't idle only when I remove the mad sensor so if I get it to work fine I'm going if not as long as I got brakes and temperature gauge ill drive it. So yes in going for sure
Gracias le estado echando muchas ganas la tuya tambiem ta chida!
  • 1 month later...
As many of u know I made it to Canby in with the ka running, idling, nd no problems. But u better post some past due updates on how I got it to idle n wat not so here it is
Here are the lil adapter tubes I made after cutting the intake to make it fit.
And the reason y it wouldn't idle is cuz of a vacuum leak, actually a few. I replaced some skinny hose towards the back by the idle control valve and replaced the sensor on there too and finally it was also leaking from one of the injectors I just replaced the rubber grommet for it, tried it fired right up like usual but this time it idled! After that I only had bout 3 days to install new electric temp gauge n to get ready for canby.
  • 4 months later...
  • 1 month later...
