k-autic Posted April 27, 2013 Author Report Share Posted April 27, 2013 O yeah I do cuz guess wat else I got ready! TADA! Quote Link to comment
heretic Posted April 29, 2013 Report Share Posted April 29, 2013 My idler was a breeze but the pitman arm.. That's no joke, I gave up on it. Did you use any heat, I was afraid too, or did you just go cave man 101 on it & beat the hell out of it.? Taking the idler arm nd pitman was a bitch but I got them! Quote Link to comment
k-autic Posted May 1, 2013 Author Report Share Posted May 1, 2013 My idler was a breeze but the pitman arm.. That's no joke, I gave up on it. Did you use any heat, I was afraid too, or did you just go cave man 101 on it & beat the hell out of it.? I used caveman 101 took a while but got it also I rented the pitman arm fork from o'rilleys for 10 bucks! It helped when I stomped my 230 lbs on the fork 1 Quote Link to comment
Wide14u Posted May 1, 2013 Report Share Posted May 1, 2013 what the are the sparks Quote Link to comment
Farmer Posted May 1, 2013 Report Share Posted May 1, 2013 Wow, you got it running already. Impressive 1 Quote Link to comment
heretic Posted May 1, 2013 Report Share Posted May 1, 2013 :) hahaha right on. apparently I just need to man up & give it a beat down. I used caveman 101 took a while but got it also I rented the pitman arm fork from o'rilleys for 10 bucks! It helped when I stomped my 230 lbs on the fork Quote Link to comment
Farmer Joe Posted May 1, 2013 Report Share Posted May 1, 2013 i think this truck is gonna be fast as hell.. i wanna go for a ride already! Quote Link to comment
k-autic Posted May 1, 2013 Author Report Share Posted May 1, 2013 what the are the sparks The sparks were coming from the starter, the positive was a lil loose on it but I tightened it up. Wow, you got it running already. Impressive Thanks it was a test to make sure the wiring was correct and that it fired up, but she's alive! But it dies like few seconds later I need to plug n connect all the vacuum stuff and button few things up still. :) hahaha right on. apparently I just need to man up & give it a beat down. Keep at it it took me bout 2 hours of jumping on it and with the fork on it to get it just don't give up. i think this truck is gonna be fast as hell.. i wanna go for a ride already! I want to go for a ride on yours. Quote Link to comment
k-autic Posted May 17, 2013 Author Report Share Posted May 17, 2013 This my cooling set up And the intake Imma have to change it up but it was to test it Then u took it to get the down pipe work ill post pic later Quote Link to comment
sick620 Posted May 17, 2013 Report Share Posted May 17, 2013 damn son nice... are you going to canby? :) Quote Link to comment
Peter_Pablo Posted May 17, 2013 Report Share Posted May 17, 2013 que perro esta quedando tu datsun man que bueno que mas y mas datsun estan resurgiendo por doquier y unos rinsitos de titan y uff quedara con madres ese datsunsito en hora buena felicidades por tan buen proyect :thumbup: 1 Quote Link to comment
k-autic Posted May 17, 2013 Author Report Share Posted May 17, 2013 damn son nice... are you going to canby? :) I'm trying to get it to idle it used to then I took it to get the down pipe made turned it on it felt fishy then drove it bout a block ant it stalled after that it won't idle only when I remove the mad sensor so if I get it to work fine I'm going if not as long as I got brakes and temperature gauge ill drive it. So yes in going for sure Quote Link to comment
k-autic Posted May 17, 2013 Author Report Share Posted May 17, 2013 que perro esta quedando tu datsun man que bueno que mas y mas datsun estan resurgiendo por doquier y unos rinsitos de titan y uff quedara con madres ese datsunsito en hora buena felicidades por tan buen proyect :thumbup: Gracias le estado echando muchas ganas la tuya tambiem ta chida! Quote Link to comment
sick620 Posted May 18, 2013 Report Share Posted May 18, 2013 this needs to be Nanos KA-autic 620... know what im saying? ;) 1 Quote Link to comment
k-autic Posted May 18, 2013 Author Report Share Posted May 18, 2013 this needs to be Nanos KA-autic 620... know what im saying? ;) Lol heck yes Quote Link to comment
k-autic Posted June 19, 2013 Author Report Share Posted June 19, 2013 As many of u know I made it to Canby in with the ka running, idling, nd no problems. But u better post some past due updates on how I got it to idle n wat not so here it is Here are the lil adapter tubes I made after cutting the intake to make it fit. And the reason y it wouldn't idle is cuz of a vacuum leak, actually a few. I replaced some skinny hose towards the back by the idle control valve and replaced the sensor on there too and finally it was also leaking from one of the injectors I just replaced the rubber grommet for it, tried it fired right up like usual but this time it idled! After that I only had bout 3 days to install new electric temp gauge n to get ready for canby. Quote Link to comment
k-autic Posted June 26, 2013 Author Report Share Posted June 26, 2013 now for some canby pics! 2 Quote Link to comment
Eagle_Adam Posted November 19, 2013 Report Share Posted November 19, 2013 how the fuck did i miss this at canby........ Quote Link to comment
Farmer Joe Posted December 22, 2013 Report Share Posted December 22, 2013 recent engine pics.. Quote Link to comment
Eagle_Adam Posted December 30, 2013 Report Share Posted December 30, 2013 looks good, cant wait till mine runs :/ Quote Link to comment
Farmer Posted December 30, 2013 Report Share Posted December 30, 2013 Looking good K-autic. Miss seeing you post Thanks Neil for the pics Quote Link to comment
k-autic Posted December 31, 2013 Author Report Share Posted December 31, 2013 i know i know im slacking this truck is just too much fun! its been keeping me occupied but i got pics n post coming up! stay tuned! 1 Quote Link to comment
k-autic Posted December 31, 2013 Author Report Share Posted December 31, 2013 looks good, cant wait till mine runs :/ Cant wait too see it let me know if you need help on anything Quote Link to comment
Farmer Joe Posted December 31, 2013 Report Share Posted December 31, 2013 man i drove by and this things still sittin the same spot... get to work! Quote Link to comment
