Datsy620 Posted February 1, 2012 Report Share Posted February 1, 2012 im driving my datsun and everything is fine. then i get home. couple hours later i go back in my datsun turn it on and now its not showing how much gas i have.. what can it be please help. is there a simple problem that could have happened thank you Quote Link to comment
skunk Posted February 1, 2012 Report Share Posted February 1, 2012 is that the only thing on the dash not working? could be a ground, a fuse, follow the wire from the fuse box to the gas gauge. have you ever cleaned your fuse box? my first 620 would do lots of funny stuff till i gave its box a good cleaning Quote Link to comment
Datsy620 Posted February 1, 2012 Author Report Share Posted February 1, 2012 to skunk: yeah that's the only thing that is wrong on the dash.. no I've never cleaned the box before. okay I'm going to follow the line. I'm gnna do that right now thank you very much . Quote Link to comment
skunk Posted February 1, 2012 Report Share Posted February 1, 2012 take the fuse box out and soak it in lemon juice. maybe take a wire brush to the metal contacts before and after. if you haven't done this kind of stuff before, be sure to take some pic of how things were before you took them apart. Quote Link to comment
]2eDeYe Posted February 1, 2012 Report Share Posted February 1, 2012 http://community.ratsun.net/topic/34870-fuel-gauge-problem/ Good thread on fuel guage issues :) Quote Link to comment
Datsy620 Posted February 1, 2012 Author Report Share Posted February 1, 2012 thank you very much it now works Quote Link to comment
Eagle_Adam Posted February 1, 2012 Report Share Posted February 1, 2012 what fixed the issue? Quote Link to comment
]2eDeYe Posted February 1, 2012 Report Share Posted February 1, 2012 Posting on ratsun.net of course. :lol: Quote Link to comment
Datsy620 Posted February 2, 2012 Author Report Share Posted February 2, 2012 lol it was something stupid and small. the little cable connector was disconnected hahahah. DIfferent problem.. both my headlights dont turn on.. lol it happened before my gasoline gauge went Quote Link to comment
skunk Posted February 2, 2012 Report Share Posted February 2, 2012 same answer LOL Quote Link to comment
datzenmike Posted February 2, 2012 Report Share Posted February 2, 2012 DIfferent problem.. both my headlights dont turn on.. lol it happened before my gasoline gauge went More info.... low beams? one on one off??? Or high/low beams You have low beams but not high beams????? Quote Link to comment
Datsy620 Posted February 2, 2012 Author Report Share Posted February 2, 2012 lol thanks skunk. i think imma do it this time. hahaha datzen: niether my high beams nor regular beams work. Quote Link to comment
TENDRIL Posted February 2, 2012 Report Share Posted February 2, 2012 im assuming they worked before? do the running lights work? some times the pull switch can be wiggled. and or the connection from the switch to the harness slightly corroded check to see if there is power getting to the connectors at the beams find the headlight relay, turn the key over to on, pull the switch/or click the high beam lever foward listen for a click.. if nothing than most likely not getting power to the relay :huh: Quote Link to comment
ggzilla Posted February 2, 2012 Report Share Posted February 2, 2012 1. Buy new headlights. 2. If that doesn't solve the problem, buy new relay 3. If that doesn't solve the problem, buy new headlight switch 4. If that doesn't solve the problem, buy new Headlight Wiring Kit If that doesn't solve the problem, call owner and tell them it can't be fixed. Quote Link to comment
Datsy620 Posted February 2, 2012 Author Report Share Posted February 2, 2012 @tendril they did work before they just went out about 3 days ago. so im like wtf 0.o alright imma try what your telling me. Quote Link to comment
]2eDeYe Posted February 2, 2012 Report Share Posted February 2, 2012 1. Buy new headlights. 2. If that doesn't solve the problem, buy new relay 3. If that doesn't solve the problem, buy new headlight switch 4. If that doesn't solve the problem, buy new Headlight Wiring Kit If that doesn't solve the problem, call owner and tell them it can't be fixed. :lol: @tendril they did work before they just went out about 3 days ago. so im like wtf 0.o alright imma try what your telling me. Check the fuse, then the contacts. I have to jiggle mine a lil bit. Quote Link to comment
TENDRIL Posted February 2, 2012 Report Share Posted February 2, 2012 2eDeYe' date='02 February 2012 - 12:14 PM' timestamp='1328213670' post='625559']:lol: Check the fuse, then the contacts. I have to jiggle mine a lil bit. yea forgot to metion replace the fuses even tho it might look intack some times they can be bad at the caps... :rolleyes: Quote Link to comment
ComicArtist Posted February 2, 2012 Report Share Posted February 2, 2012 My bet would be a fuse. Happens to me pretty often. Quote Link to comment
