Laecaon Posted January 23, 2012 Report Share Posted January 23, 2012 Um is GM synchromesh yellow metal safe? Quote Link to comment
metalmonkey47 Posted January 23, 2012 Author Report Share Posted January 23, 2012 (edited) A quick submerge shouldn't hurt the tranny or diff. The vents are high up on the tops. If the vehicle sits in the water long enough and cools, the warm contracting air will suck water in. I doubt this has happened so... If you haven't changed either the trans or diff in 30K then do so. Otherwise check the oil level with finger. Water sinks so it will displace the oil up. If it pours out the fill hole then it needs draining. If the oil is milky or silvery change it. Thanks for the heads up Mike! I haven't serviced the diff since I got it, and I don't know when it was done, so I'm gonna go ahead and do it. The Oil could use changing so I can try and clean the vent tube anyways. Um is GM synchromesh yellow metal safe? Yup! Says "Safe for brass and other yellow metals" right on the front. The Penzoil stuff is awesome. Edited January 23, 2012 by metalmonkey47 Quote Link to comment
I'm BLUE Posted January 23, 2012 Report Share Posted January 23, 2012 :thumbup: Quote Link to comment
