510 rear crossmember
Ant-dat
sorry if this has been asked before,
I have been looking at a couple kit's for camber/toe on rear of 510,
kit 1 from datsport
Toe in 1mm each side total 2mm. referenced from the front. Camber 0.5 neg
Kit 2 FutoFab
1.5 deg positive to 3 deg negative camber
1" total toe out to 1.4" total toe in
kit 2 looks to have much more adjustment,
Has anyone used either of these kits? if so what was you findings? Which kit is best, easy of adjustment and holding adjustment?
cheers
  • Replies 12
  • 1 month later...
Kit 2 from FutoFab is the same kit produced by Byron Meston in British Columbia. Top notch quality, but installing it is up to the installer to do a good job.
There is a lot of info on these on the510realm.com, take a few minutes and search the realm. I'm sure you'll find lots of threads regarding them.
FWIW, I'll be using this kit when money permits and having it professionally installed/inspected. That's not a place you want to skimp on having it done RIGHT the first time.
At the same time, it's a good idea to punch out a bigger exhaust hole too :D
  • 1 year later...
2 year bump?
Well, yeah. There doesn't seem to be very many people that have used the DatSport setup, and I'm looking for any feedback I can get.  And any input he may have will only help the next person that comes across this thread with the same question.
Probably because its expensive to ship from Australia. Sign up for Ozdat. I bet more people have used it there.
