Shagy Posted January 16, 2012 Report Share Posted January 16, 2012 I have been thinking about this for a while. So I made a little test emblem. The actual one when I'm done will be about 1/4" thick. I'm also going to make the "DATSUN" emblems like on the fenders and if wanted...I'll make a "RATSUN" one. I've also started to make the glove box logo thats on the 510's, not sure if it is on other lines... Here is the one that I did.... Please let me know your thoughts. I'm thinking about making these and reselling. they would attach with double sidded tape. Quote Link to comment
Wide14u Posted January 16, 2012 Report Share Posted January 16, 2012 i like this looks good Quote Link to comment
DAT510 Posted January 16, 2012 Report Share Posted January 16, 2012 This does look good. Will you be making the Ratsun ones with the three prongs? Quote Link to comment
Eagle_Adam Posted January 16, 2012 Report Share Posted January 16, 2012 looks sharp :) - id be in for a ratsun set Quote Link to comment
Shagy Posted January 16, 2012 Author Report Share Posted January 16, 2012 This does look good. Will you be making the Ratsun ones with the three prongs? nope, they will all be double side tape. Quote Link to comment
TENDRIL Posted January 16, 2012 Report Share Posted January 16, 2012 very nice im in for a ratsun one Quote Link to comment
DAT510 Posted January 16, 2012 Report Share Posted January 16, 2012 nope, they will all be double side tape. Cooooooooooooooool!!!!! Quote Link to comment
Shagy Posted January 16, 2012 Author Report Share Posted January 16, 2012 I'm going to look into selling them as sets.... so it would be like this... 1 -510- emblem, 3 fender "datsun" emblems. On the Ratsun ones... should I do 2 or 3 fender emblems? Quote Link to comment
Hardwyre Posted January 16, 2012 Report Share Posted January 16, 2012 What are they made from? Is there any way to put a 45 degree bevel on the edges of the numbers? Quote Link to comment
Shagy Posted January 16, 2012 Author Report Share Posted January 16, 2012 What are they made from? Is there any way to put a 45 degree bevel on the edges of the numbers? laser etched acrylic... no bevels here. basically 2D stuff. Quote Link to comment
Skib Posted January 16, 2012 Report Share Posted January 16, 2012 laser etched acrylic... tell me moar of this process..... Quote Link to comment
Shagy Posted January 17, 2012 Author Report Share Posted January 17, 2012 I cut shit a lazer yo!!! Ill PM ya.... Quote Link to comment
javyz510 Posted January 17, 2012 Report Share Posted January 17, 2012 Look clean! Quote Link to comment
Shagy Posted January 17, 2012 Author Report Share Posted January 17, 2012 Did these over the weekend also. Quote Link to comment
paradoxx Posted January 17, 2012 Report Share Posted January 17, 2012 slick!!! I would run a ratsun set on the autox'r..... 1 Quote Link to comment
Shagy Posted January 30, 2012 Author Report Share Posted January 30, 2012 Okay..I'm basically done with this. This is the 1st one with the new/proper material... Now just have to do the "Datsun" & "ratsun" ones.. Quote Link to comment
Hardwyre Posted January 30, 2012 Report Share Posted January 30, 2012 Okay..I'm basically done with this. This is the 1st one with the new/proper material... Now just have to do the "Datsun" & "ratsun" ones.. Looks moar epic with proper thickness. :) Is your laser powerful enough to do metal? Quote Link to comment
Shagy Posted January 30, 2012 Author Report Share Posted January 30, 2012 What thickness do you have in mind? I can etch on anything....but I'm not sure it would cut anything too thick. I believe is 30w. Quote Link to comment
Hardwyre Posted January 30, 2012 Report Share Posted January 30, 2012 What thickness do you have in mind? I can etch on anything....but I'm not sure it would cut anything too thick. I believe is 30w. 30w? I was thinking making emblems out of 1/4" aluminum, but I'll probably have to use a CNC for those. Quote Link to comment
