Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 so can the apexi Where??? Does it say that???? how does it bypass the ECU????? the Vtec controllers just kick in vtec Earlier they DONT Control the Injectors,BTW How many Hondas have you worked on?? Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 mmmk, i under stand the injector thing now, im going to keep trying to get ahold of the origional owner to see whats actually been done Quote Link to comment
Wide14u Posted January 12, 2012 Report Share Posted January 12, 2012 if it was just the swap why would they change the injectors you think that they had to build this motor Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 ok, so the engine harness, and 02 sensors i am looking for is for a d16z6? correct? and then the p28 ecu, and the adapter harness.... Yes and yes You basically need all the stuff injectors ecu harness like your swapping in a d16z6 the obd2 stuff is a nightmare and you want obd1 easier to "tune" if you wanna chip it for more power less emissions Crap than obd2 the only difference between d16z6 and the y8 is y8 has higher compression the bottom ends are a little weaker so i wouldnt turbo it just keep in N/A Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 if it was just the swap why would they change the injectors you think that they had to build this motor OMFG???!!!!??? The d16y8 injectors (the motor thats swapped in)WILL NOT WORK WITH THE STOCK ECU SO the Guy who did swap used the stock injectors D16A6 in the D16Y8 motor Quote Link to comment
Skulptr Posted January 12, 2012 Report Share Posted January 12, 2012 any civic that isnt still owned by its original owner is a piece of shyt. buy something, anything, else. if you were here and bought that car, you would get pulled over every other day simply because of the way it looks, literally. Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 kami, will the z6 injectors work at all with the ctock ecu to the car? or just not in vtek? Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 and what i mean by hard, is willit need to be tuned. installing the parts is no problem for me, but just the fact of will it work, and not need to be tuned or anything It will work fine if you use ALL d16z6 parts ECU injectors Dizzy it will be just like a stock 1992-1995 civic si,if you want more power than Tune/chip it have a shop use a dyno and Bam!!! you could be pushing 130hp Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 yea, well in this town, i am known by everyone. i am a technician at a GM dealership, and most people like me. and everyone knows i like to drive junk cars for fun. Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 kami, will the z6 injectors work at all with the ctock ecu to the car? or just not in vtek? NO the stock ECU a pm6?? I think (its been awhile) The stock injectors use a resistor box the z6 ones dont Quote Link to comment
Skulptr Posted January 12, 2012 Report Share Posted January 12, 2012 would never consider a civic to be fun. look for an accord. bigger engine, same mpg.s and quite a bit more fun, plus a little respect. come on, you work for gm, you should know better than this... Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 no, the only reason i ask if it will work at all, is becuase he said the vtek, doesnt work, and its sorta gutless compared to his buddys 95 vtek. so i thought maybe the injectors were wrong for the ecu, and thats why vtek may didnt work. i will buy it and find out. i think Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 yea, but i also drve a datsun.... who looks up to them as glorious vehicles? besides us, and old men reliving there child hood? Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 i just need something decent on gas Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 i just need something decent on gas Well you can run it like it is it just wont have vtec,so your lookin at 32-36 in town 40+ on highway Quote Link to comment
Wide14u Posted January 12, 2012 Report Share Posted January 12, 2012 OMFG???!!!!??? The d16y8 injectors (the motor thats swapped in)WILL NOT WORK WITH THE STOCK ECU SO the Guy who did swap used the stock injectors D16A6 in the D16Y8 motor so what are you trying to say Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 so what are you trying to say trying to say... go away Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 Well you can run it like it is it just wont have vtec,so your lookin at 32-36 in town 40+ on highway ok, i was just a little worried it might not be safe for something. Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 ok, i was just a little worried it might not be safe for something. No it;ll be fine the ECU thinks its a NON vtec motor and not having Vtec hooked up wont hurt anything u just wont go as fast Besides Vtec dont kick in till 5400 stock anyway Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 yea, its mostly intown driving Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 And according to "Someone" I don't help people on this forum????? hahahahahahahahahahahaha!!!!! :lol: :P Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 yea, its mostly intown driving Redlines at 7200 so you'll still have some fun Quote Link to comment
lil89ram50 Posted January 12, 2012 Author Report Share Posted January 12, 2012 WHAAAAAA 7200 is redline! i guess i might be looking to getting this vtek fixed, does it really do that much more anywany? never driven one before Quote Link to comment
datzenmike Posted January 12, 2012 Report Share Posted January 12, 2012 Four pages of head pounding. 1 Quote Link to comment
Guest kamakazi620 Posted January 12, 2012 Report Share Posted January 12, 2012 WHAAAAAA 7200 is redline! i guess i might be looking to getting this vtek fixed, does it really do that much more anywany? never driven one before Yeah it does i drove a built d16y8 for the detail shop i worked for and lets say coming out of second i was doing 75 in 2 blocks and if you go B series the B16 redlines at 9000-9500 Quote Link to comment
