Mista510 Posted December 18, 2011 Report Share Posted December 18, 2011 I got this drip coming from the engine after starting up the car from what looks like the drain plug for the block. how do I go about fixing it? Quote Link to comment
datzenmike Posted December 18, 2011 Report Share Posted December 18, 2011 Open and close several times to get a better seat. If stuck don't force it, it may snap off. Be prepared with a propper threaded pipe plug. 08931-30410 is the plug. Used on L and Z engines. Quote Link to comment
Mista510 Posted December 18, 2011 Author Report Share Posted December 18, 2011 thank you sir Quote Link to comment
Jester Posted December 18, 2011 Report Share Posted December 18, 2011 Just yard it off and put a plug in it. Quote Link to comment
DanielC Posted December 18, 2011 Report Share Posted December 18, 2011 Remember Datsun engines use the BSP (British Standard Pipe) fittings for the plugs. It is not a common "go to home depot and get a plug" fitting. Use the part number supplied to get the plug from a Nissan dealer. Quote Link to comment
datzenmike Posted December 18, 2011 Report Share Posted December 18, 2011 .... or of an old block. What Datsun owner doesn't have a couple? I just go out and cut the lawn to get the part I want. Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 Remember Datsun engines use the BSP (British Standard Pipe) fittings for the plugs. Ah, just like american engines. Quote Link to comment
DanielC Posted December 19, 2011 Report Share Posted December 19, 2011 BSP is NOT just like the American engines. This chart had the differences. http://pipeandhose.com/node/2 Quote Link to comment
ggzilla Posted December 19, 2011 Report Share Posted December 19, 2011 Good to know. Thanks for the chart. Quote Link to comment
