mklotz70 Posted December 2, 2011 Report Share Posted December 2, 2011 I did a few vids of taking the tumbler out of the 521 ign switch. Good info if you need to re-key or you're just curious about what the switch looks like inside :) http://www.bluehandsinc.com/ignition-switch.html 1 Quote Link to comment
jefe de jefes Posted December 2, 2011 Report Share Posted December 2, 2011 Thanks again for sharing. When they tried stealing my truck a while back they took my switch and cut the wiring to it on the back. I ended up grabbing another switch then I pulled the tumbler out and ground down the little tabs on the tumbler while my key was in the switch. It works fine but rekeying the switch would be better. 1 Quote Link to comment
Uncle Laulau Posted December 2, 2011 Report Share Posted December 2, 2011 Your site is sick tastic! Can't believe I haven't run across it till today. Keep up the good work. 1 Quote Link to comment
hollywood7600 Posted December 2, 2011 Report Share Posted December 2, 2011 Very interesting, I now have an idea how the ignition switch works. 1 Quote Link to comment
mklotz70 Posted December 2, 2011 Author Report Share Posted December 2, 2011 Thanks guys. Yep...re-keying would def be better. If you can take them the tumbler like that, they can figure out the new key pretty easily. 1 Quote Link to comment
boxboy Posted January 15, 2012 Report Share Posted January 15, 2012 Mike, thanks for the vids. Am I understanding that if you take the switch mechanism out there is really no solid guarantee that you can get it back together reliably? My switch is acting funny. If you just start the truck and let go of the key, it will slip back a bit and short out the contact and stall. Same with the ACC position. Once you turn it to accessory, you may have to jiggle it a bit to get the ALT/OIL lights to come on. I am not wanting to re-key, and I don't see any 520 switches offered for sale anywhere, just the 521 switches. I believe the difference is that the wiring on the back of the switch is laid out differently. Am I doomed pretty much to getting a 521 switch and trying to wire it up? Any advice appreciated. 1 Quote Link to comment
mklotz70 Posted January 15, 2012 Author Report Share Posted January 15, 2012 If you don't want to cut your wiring harness for the other plug, just use male spade terminals on a short length of wire.....male goes into your wiring harness, the female on the other end will go onto your plug where you need it to be. Hopefully, someone else will verify this or correct it, but I'm pretty sure there's no ACC on the 520 switch and there is on the 521.....if that's the case, you simply have one connection not made on the switch. Quote Link to comment
boxboy Posted January 15, 2012 Report Share Posted January 15, 2012 You are right Mike, there isn't a ACC, just an OFF, ON and Start. I believe it is only three wires, and the 521 switch has 5 connectors. I am going to go pull mine right now and see what I find. Quote Link to comment
boxboy Posted January 16, 2012 Report Share Posted January 16, 2012 Yes, I was correct Mike. There are three tab connections. Two vertical with one horizontal over the top of the other two. Looking at the back of the switch there are three copper tabs bent over that I am assuming hold the switch in. I am guessing that if I am careful I can get the switch out, clean the contacts and put it back together. HOwever, I am nervous about all the springs and whatnot falling out and not knowing where they go, or how to get them back in. I will have to see if I can find a schematic somewhere. Quote Link to comment
DanielC Posted January 16, 2012 Report Share Posted January 16, 2012 I had a 1967 single headlight 520, the wires on the ignition switch did not have a molded plug. just 1/4 female spade connectors that plugged into the male connectors on the switch. Quote Link to comment
boxboy Posted January 16, 2012 Report Share Posted January 16, 2012 I couldn't get the switch assembly out to clean. I am wondering if anyone knows how to wire the 521 switch with the three wire set up. Is it just the same with connection 4 and 5 left off? Can I mess something up by trial and error? Quote Link to comment
mklotz70 Posted January 16, 2012 Author Report Share Posted January 16, 2012 I took a quick look at the wiring schematics. I compared it to the 620 switch since olddatsuns.com doesn't have a PL521 diagram....only an L521(which is the same as the 520). Looks like the 3 wires are the same between them. White ....battery BY ....start BW ....ignition The ignition wire feeds everything on your 520, so the other two connectors aren't needed on the switch. Quote Link to comment
boxboy Posted January 16, 2012 Report Share Posted January 16, 2012 Where can I find which number corresponds to which wire? My trucks start switch is simply labeled "1,2 and 3" not "ST, IGN, BATT" So I would need to know which wire to connect to which number on the 521 switch. I am seeing that Rock Auto has them for about $23 shipped to me, But I can't see the front of the switch to make sure it is the dash mount switch I am looking for. Quote Link to comment
mklotz70 Posted January 16, 2012 Author Report Share Posted January 16, 2012 Here's a typical, universal ignition switch you can get at most parts stores....should mount up in the dash with no problems. http://www.ebay.com/itm/UNIVERSAL-IGNITION-STARTER-SWITCH-/400227750183?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item5d2f6ed127 Quote Link to comment
boxboy Posted January 16, 2012 Report Share Posted January 16, 2012 Yeah, I was hoping I could get a switch that I could swap my lock mech. into so I don't have to lose my Nissan Key that works with my door locks. Quote Link to comment
mklotz70 Posted January 17, 2012 Author Report Share Posted January 17, 2012 makes sense. I'll bet the one that RA has is the same as the one I just posted. I'd be checking ebay and ratsun for stock switches. Quote Link to comment
boxboy Posted January 26, 2012 Report Share Posted January 26, 2012 I took a quick look at the wiring schematics. I compared it to the 620 switch since olddatsuns.com doesn't have a PL521 diagram....only an L521(which is the same as the 520). Looks like the 3 wires are the same between them. White ....battery BY ....start BW ....ignition The ignition wire feeds everything on your 520, so the other two connectors aren't needed on the switch. Mike, I don't mean to belabor this topic, but I am finding the 521/520 options to be pretty spendy. There are a few 620 switches on ebay that look close except for the extra connections. Are you fairly confident that I can make a 620 switch work? Do you know if I could swap bezels and key cylinders with my current 520 switch? It will save me about $50 to do so, or save me paying a lot for a used 40 year old switch. Thanks in advance. Quote Link to comment
mklotz70 Posted January 27, 2012 Author Report Share Posted January 27, 2012 How the 620 switch fits physically.....no clue. I've never had a 620. Redeye, Datsunaholic, Datzenmike......anyone of them might have a much better idea about the fit. Sorry I don't have an answer. Quote Link to comment
