barman1971 Posted November 21, 2011 Report Share Posted November 21, 2011 Does anybody know anything about this carb? will it bolt on not prob? will it give me any BHP gain? is it really worth 300$ . Im running a very stock old ass hitachi right now and in the market for an upgrade! http://www.ebay.com/itm/Holley-400-7-Datsun-B210-Carburetor-NEW-1397CC-/200668856637?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2eb8cbc13d Quote Link to comment
datzenmike Posted November 21, 2011 Report Share Posted November 21, 2011 Looks like the Weber licensed by Holly to build. At least it's new and you shouldn't have trouble with it. Make sure it has all the hook-ups that are on you carb like an idle cut solenoid, vacuum advance. Generally they give some performance increase and economy decrease over the very good Hitachi . Quote Link to comment
Dguy210 Posted November 22, 2011 Report Share Posted November 22, 2011 For $300 you can get a brand new Weber for the B210 also though. Datzenmike is right: From my experience with the Weber, bolts on ok, need to remove the EGR to clear. Definitely see decreased mpg, I average in the mid-low 30's now on the freeway, the Hitachi would get me into the mid 40's on the freeway. The seat of the pants feel is much better though, and it definitely seems to pull much harder at the higher RPM's. The Weber is much much easier to leadfoot than the Hitachi and this will hurt the mpg. Caveat: my carb came from another B210, I haven't finished the final tune on it yet, but it is pretty close, so a little better economy might be possible. Kinda depends on what you want, for a daily driver I would stick with the Hitachi, OEMsurplus has a NOS ~77-78 for ~125$. For a lightly used fun car, the Weber feels much better. Quote Link to comment
king bee66 Posted November 22, 2011 Report Share Posted November 22, 2011 that carb is tiny Quote Link to comment
CWhip Posted November 22, 2011 Report Share Posted November 22, 2011 Something else to think about, air cleaner and adapter. I like my weber as well. Still get low 30's mpg but it's a lot more fun to drive. Quote Link to comment
JAS Posted November 22, 2011 Report Share Posted November 22, 2011 Go with the Weber and get the adapter plate for your manifold. I put together the adapter plate and manifold, then hogged out the access meat to allow better flow under the carb into the plenums. The carb mount on the 210 is notoriously tiny, compared to the plenums or outlet of the Weber or Holley carbs. Here is a picture of a weber on an A14/H89 intake without EGR. Webers generally come with the air cleaner, and lots of other options readily aavailabe and really easy to work on... I can tune it, and i am carb retarded. Quote Link to comment
ggzilla Posted November 23, 2011 Report Share Posted November 23, 2011 The weber will only give a gain above 5,000 RPM. Below 5,000 the Hitachi is superior. Quote Link to comment
dat521gatherer Posted December 8, 2011 Report Share Posted December 8, 2011 Go with the Weber and get the adapter plate for your manifold. I put together the adapter plate and manifold, then hogged out the access meat to allow better flow under the carb into the plenums. The carb mount on the 210 is notoriously tiny, compared to the plenums or outlet of the Weber or Holley carbs. Here is a picture of a weber on an A14/H89 intake without EGR. Webers generally come with the air cleaner, and lots of other options readily aavailabe and really easy to work on... I can tune it, and i am carb retarded. Is your carb on backwards?? I have a pic of a a14 with a weber and the throttle cable is towards the firewall. Quote Link to comment
ggzilla Posted December 8, 2011 Report Share Posted December 8, 2011 DGV and DFV are the same but mirror image. or He has the primary and secondaries not lined up with the manifold primary/secondary. Keep in mind that the A14 pulls a lot more airflow than the J13. A-series is a more advanced, more powerful cylinder head design. Quote Link to comment
JAS Posted December 8, 2011 Report Share Posted December 8, 2011 I do have a H89 shaved head on this motor with the matching intake and exhaust manifolds. My daughter has a stock 210 with the A14, she askes why my car sounds so loud. The high compression and webber really make a difference with the freeflowing head. sounds like a lumpy cam. Still have the stock exhaust on it. Quote Link to comment
