Siqx20 Posted November 10, 2011 Report Share Posted November 10, 2011 Im about to pull my cab off but cant figure out how to remove my steering column. I thought i knew how and i was wrong. tried searching and all i found was how NOT to remove it. lol so now i need to kno how i DO remove it. plz help. need a answer asap before i lose motivation for the day lol Quote Link to comment
]2eDeYe Posted November 10, 2011 Report Share Posted November 10, 2011 First pop the tie rods off the pitman arm. Then pull the steering wheel, shroud and blinker assy. You have to unbolt it from the dash, the firewall and the steering box at the frame. Then it should come out from the engine bay. You may want to pull the radiator for that if you haven't already. Edit: Gear oil will run out if you tilt it up for too long :) Quote Link to comment
datsunaholic Posted November 10, 2011 Report Share Posted November 10, 2011 As stated above. It helps of the engine is already out, but I've pulled one with the engine still in. It did dump oil all over the cab floor. If the engine is out it's possible, though not nearly as easy, to pull the steering box through the core support (where the radiator and grille should be) but it's easier to just go up and over. Oh, what wasn't stated is you remove the steering gearbox and column tube all as one unit. Quote Link to comment
datzenmike Posted November 10, 2011 Report Share Posted November 10, 2011 I lifted the cab up and back off the column once. Me and my three kids did it. Quote Link to comment
69FJWagon Posted November 10, 2011 Report Share Posted November 10, 2011 I just did this last week and the only thing that prevented me from pulling it out was the brake booster once that was out of the way it lifted straight out, slap a rubber glove over the end of the shaft so you dont get gear oil all over ( if yours is half as bad as mine its empty anyway :blink: ) Quote Link to comment
Siqx20 Posted November 10, 2011 Author Report Share Posted November 10, 2011 I just unbolted the gear box and lifted the cab off and fed it out. It was a pain. But the cab is off. Time to cut shit up! Quote Link to comment
yello620 Posted November 10, 2011 Report Share Posted November 10, 2011 What are you cutting up? Spare cab? Quote Link to comment
Siqx20 Posted November 10, 2011 Author Report Share Posted November 10, 2011 The frame. The truck is getting bagged. Frame up build. Quote Link to comment
pharouh Posted November 13, 2011 Report Share Posted November 13, 2011 I just unbolted my box. If you take the bed off,it's real easy. All you have to do is slide the cab back and up.Take off as much stuff as you can to make it lighter. Quote Link to comment
Siqx20 Posted November 13, 2011 Author Report Share Posted November 13, 2011 Yeah that's what I did actually. Quote Link to comment
