calm_bomb Posted October 22, 2011 Report Share Posted October 22, 2011 Went to replace my 2-point dizzy with p/c with a single-point SSS dizzy to put the electronic ignition conversion kit from Pertronix in. The old one points at #1, but the new one points at #2. Any thoughts or links? Here's what I see when I put the new one in: Old dizzy pointing at #1 New dizzy pointing at #2 ~derek Quote Link to comment
nismo dr Posted October 22, 2011 Report Share Posted October 22, 2011 if that is tdc comp, make that #1, 1-3-4-2 Quote Link to comment
DISLEXICDIME Posted October 22, 2011 Report Share Posted October 22, 2011 Are you sure it is in the slot? Quote Link to comment
Just Joel Posted October 22, 2011 Report Share Posted October 22, 2011 That dizzy is from an l18 so the pedestal base might be different. Just change the plug wires so that the rotor points to number one cylinder and your good to go ;) I'm going through a similar problem with having the wrong base on my matchbox dizzy and had to rotate the shaft and relocate the first cylinder wire... Later Joel Quote Link to comment
Just Joel Posted October 22, 2011 Report Share Posted October 22, 2011 if that is tdc comp, make that #1, 1-3-4-2 Bingo... Quote Link to comment
banzai510(hainz) Posted October 22, 2011 Report Share Posted October 22, 2011 motor at TDC?????????? 11.28 position on slot?you using the same timming plate thats underneath the distributor 1 Quote Link to comment
datzenmike Posted October 22, 2011 Report Share Posted October 22, 2011 New dizzy pointing at #2 Just move all the wires one position clockwise and you're good. This is now the #1 position. Quote Link to comment
calm_bomb Posted October 23, 2011 Author Report Share Posted October 23, 2011 Thanks guys. What once was #2, is now #1... I resolved to this, but needed a second opinion before firing her up. You guys rock. Thanks again for the dizzy Joel :] Quote Link to comment
Creepy Cruiser Posted October 23, 2011 Report Share Posted October 23, 2011 Yep, I've had to do this in the past on a few myself, lol. Quote Link to comment
hogboy52 Posted October 23, 2011 Report Share Posted October 23, 2011 Judging fro the position of the dist. cap slot, it is at the 1&1/2 position not #2. Never mind, The first pic it points at the clip and is half-way. Quote Link to comment
