jdmdime Posted September 1, 2011 Report Share Posted September 1, 2011 I have my steering linkage off the car right now and I just realized how hard it is to rotate the idler arm by hand. That has to put some pressure on the steering feedback. Has anyone ever tried to fit roller bearings in there to get a softer steering feedback? As well as a tighter linkage. Quote Link to comment
datzenmike Posted September 1, 2011 Report Share Posted September 1, 2011 Is it greased? Quote Link to comment
jdmdime Posted September 1, 2011 Author Report Share Posted September 1, 2011 It looks semi new. I can't find the zerk fitting on it. How would I go about greasing the bushing? Quote Link to comment
datzenmike Posted September 1, 2011 Report Share Posted September 1, 2011 Hmmm looks like there isn't one on the 510. There is a metal post threaded on the one end that slides into a metal bushing with a rubber bushing over it and then the outer housing. I suppose if you have it off, unbolt it and grease the inner metal post and the metal bushing around it. Don't grease the rubber or it will swell and rot away. The 620 has a grease fitting on the idler arm. Quote Link to comment
.sunlover Posted September 2, 2011 Report Share Posted September 2, 2011 not to jack the thread, but isn't it grease zert, and zerk a measurement from a common place to check the squareness of your front end? When I was doing mobile truck alignments, zerk was a measurement from the front spring pin to the U bolts, and we bought grease zerts when we changed the spring pins. Quote Link to comment
jimz68 Posted September 2, 2011 Report Share Posted September 2, 2011 http://en.wikipedia.org/wiki/Grease_fitting Quote Link to comment
jimz68 Posted September 2, 2011 Report Share Posted September 2, 2011 The patent for the Zerk fitting was granted to Oscar U. Zerk in January 1929, Quote Link to comment
.sunlover Posted September 2, 2011 Report Share Posted September 2, 2011 thanks Quote Link to comment
wayno Posted September 3, 2011 Report Share Posted September 3, 2011 http://en.wikipedia..../Grease_fitting I guess I learned something today, I to thought it was zert.:hmm: :yawn: Quote Link to comment
jdmdime Posted September 5, 2011 Author Report Share Posted September 5, 2011 :) Quote Link to comment
srljunkie38 Posted September 23, 2011 Report Share Posted September 23, 2011 Well I thought nobody would ever ask for a bearing style idler. I've been using one on my race and installed a few sets in my customers cars. I use a delron kit and a thrust washer and bearing kit. $90 Troy Ermish ermish-racing.com Quote Link to comment
philcas1987 Posted September 23, 2011 Report Share Posted September 23, 2011 Pics!!! 1 Quote Link to comment
