Skib Posted August 18, 2011 Report Share Posted August 18, 2011 I have bags of L series lash pads. but no way of messuring them Quote Link to comment
Sealik Posted August 18, 2011 Report Share Posted August 18, 2011 Yes...there are getting few and far between. I recently got a 180 set from Motorsports....and the last 190 set I believe. Nice to have backup....larger pads can always be ground down....not up :D You did a wipe pattern on the cam/rockers after the ...."Very short break in"...? These guys might have some.... http://www.nissanraceshop.com/advanced_search_result?search_in_description=1&osCsid=afsdc4ai5q9mopa7j1al05ou72&keywords=lash+pads&x=44&y=9 Quote Link to comment
banzai510(hainz) Posted August 18, 2011 Report Share Posted August 18, 2011 My L20b "Black Magic" project motor has been in the works for quite a while now. Gettin.....ya know- "the works" - 100% old school hot rod trix - (cuz I love surprising SR swappers with what appears to be an antique) what does this mean really??????????? You do the wipe pattern ck? try Isky or the nissan dealer with the part number OR order it or try nissanparts.cc and HOPE you get lucky(sealick had a bad experience) You have bigger retainers for these .160s or just stock ones Quote Link to comment
Laecaon Posted August 18, 2011 Report Share Posted August 18, 2011 might these work? http://www.thezstore.com/page/TZS/PROD/PEM02/10-2041A Quote Link to comment
AgentOrange Posted August 19, 2011 Author Report Share Posted August 19, 2011 . Quote Link to comment
AgentOrange Posted August 19, 2011 Author Report Share Posted August 19, 2011 I have bags of L series lash pads. but no way of messuring them IF you have no need or interest in them, I will take the whole lot.!!! Just let me know.... and we can work something out. Cheers! Quote Link to comment
banzai510(hainz) Posted August 19, 2011 Report Share Posted August 19, 2011 I choose durable over powerful ?????????? You put a stock L16 in there. That would be a wise move if you its your only car http://olddatsuns.com/ http://www.youtube.com/view_play_list?p=8EF51386855F2B58 Quote Link to comment
Sealik Posted August 19, 2011 Report Share Posted August 19, 2011 If the wipe pattern is just catching the side of the rocker with the 150 pad?????..it will take more than a 160 to center 10 thousands doesn't move it a lot I assume the pattern is closet to the pivot side of the rocker....not the valve side? I grinded 1 150 pad down to 140... With my belt sander, .... :blink: Would not like to do a full set.....by hand that is Was a bitch to hold onto.... :D You can calculate the exact size of pad needed..just cut up a .010 feeler gauge into small pieces and keep sticking them under your 150(?) until the pattern is centered. Disregard any info already privy to.... :D Quote Link to comment
HRH Posted August 19, 2011 Report Share Posted August 19, 2011 You can't get those pads from Nissan? I got a set of .160 lash pads from http://www.thezstore.com/ when I built the motor for the 510. Had no problem getting them, but that was 3 years ago. Quote Link to comment
AgentOrange Posted August 20, 2011 Author Report Share Posted August 20, 2011 . Quote Link to comment
