S@nt0s Posted March 12, 2008 Report Share Posted March 12, 2008 ok i have done some research and now at the crossroads and just want some verification. i have a 72 1200 sedan that will be taking shots at the 1320 ( 1/4mile). i have 2 rear ends 1 is from a 71 510 wagon the second is from a datsun pick up. dont know which as i got it from a friend. from what i have found out is they are both H190 ( correct? look at the pics) the truck supposedly has 4.37's and the 510 3.90's both can handle the power i will be giving it with the CA18DET. now which would be more ideal just install the wagon rear end and swap in the truck axles and 3rd member? i rear up on wiki and here but just need some reassurance on this before i yank the stock rear end out. datsun pick up 510 wagon Quote Link to comment
reese Posted March 12, 2008 Report Share Posted March 12, 2008 http://www.reiderracing.com/pgpowerbrute.htm Quote Link to comment
Icehouse Posted March 12, 2008 Report Share Posted March 12, 2008 This is all stuff I have never done but though about for my 1200 sedan. The wagon has different axle spline counts than the truck axles because of the smaller axles in the wagon, but the truck diff has all kinds of aftermarket LSD's. So my idea was to get a truck axle and use it, the 521 has the same width rear end as a wagon and the 320 is even narrower. I don't know if the 320's rearend guts are the same as the 521 but someone on here should know. I bet the 320 I'd close to the same with ad the 1200. If everything works out you could buy the nissan comp locker (275$ through a dude on the bb list) and have one tuff diff, if the 320 doesn't work the 521 should. I don't think it would be to tuff the redo the leaf mounts either. The 521 leafs are 1 inch closer than the wagon if my memory is correct. Sometimes its way off haha. Get pacific coast to measure all the truck diffs since he owns them all haha Quote Link to comment
datsunaholic Posted March 12, 2008 Report Share Posted March 12, 2008 The splines are different, but you can swap out the side gears either way. Guy Selle put a set of truck splines in a 3.90 for me (traded a 4.375 H190AL for it) that I have spare if I ever build a LZ24 or Z24 in a 620. Quote Link to comment
510six Posted March 12, 2008 Report Share Posted March 12, 2008 http://www.cardomain.com/ride/674663 Look at the 8.8 , I have a friend with a 1200 with a SOHC KA 24 with a somewhat mild cam and a set of 40mm sidedrafts and a header who used to break stock 510 wagon H190 axels on a regular basis running low 13`s on slicks. Quote Link to comment
S@nt0s Posted March 12, 2008 Author Report Share Posted March 12, 2008 You talking about the late 70's mustang 8.8? I know about swaping the spiders to take the truck axels which are 29 spline right? Yea the 320 is the most narrow rear but won't find one I'm sure, I wanna work with the 2 rears I have but if worst comes to worst ill do a chevy 10bolt or just do a ford 9". Quote Link to comment
510six Posted March 13, 2008 Report Share Posted March 13, 2008 I am talking about an 8.8 from a Fox Body Mustang. http://www.mustang50magazine.com/techarticles/m5lp_0609_ford_88_inch_rear_end/index.html http://www.carcraft.com/techarticles/116_ford_8_8_rear_end/index.html My friends with high horsepower rotaries all run 8.8`s if using more than a 7" slick. Quote Link to comment
ggzilla Posted March 13, 2008 Report Share Posted March 13, 2008 8.8 (1986-up Mustang) is good for extra-heavy-torque -- 300 lb. ft. or more. It's a lot lighter than a Ford 9" yet nearly as strong. Compared to a 1200 (B110), the 320 rear is narrower, 521 and 510 wider. Drum-to-drum Width: Datsun 320 50 in - H190 diff Datsun B110: 51.36 in (1305 mm) Datsun V510: 53 in Datsun 521 53 in http://forum.ratsun.net/showthread.php?t=2401 Quote Link to comment
510six Posted March 17, 2008 Report Share Posted March 17, 2008 Check out the Supra T04S turbo , it has a Ford 8.8 with LSD. http://www.cardomain.com/ride/674663/3 Quote Link to comment
S@nt0s Posted March 18, 2008 Author Report Share Posted March 18, 2008 ya the 8.8 sounds nice but we'll see in the next month when i have time to pull the stock rearend out Quote Link to comment
b210in Posted March 18, 2008 Report Share Posted March 18, 2008 ca's respond well to really low gears. stock silvias come in 4:40 to 1. i would go numerically higher than this but not lower. what ever rear you decide to put in, you will definately have to narrow it. i would swap in the ford 8.8 as well. the best ones with the low gears and lsd are the one that came stock in the thunderbird turbo coupe. They come stock with 3:73 to 1. good luck. Quote Link to comment
69FJWagon Posted March 18, 2008 Report Share Posted March 18, 2008 Ford 8.8 is just as strong as a 9" just not as easy to swap the 3rd member in and out (use to be a mustang guy 1969 coupe) but if you are going to the drags and are going to street drive the car at all get a good LSD the stock ford LSD is :poop: I rebuilt one in my buddys 89 and shimmed it up tight for auto X and put 2 events with 2 drivers for a total of 20 runs and it was DONE Quote Link to comment
datzenmike Posted March 19, 2008 Report Share Posted March 19, 2008 CA18DET will need low low gears for 1/4 mile. Ideally you want to run our of revs just at the traps. Truck 4.375 H-190 at least, but you'll need an LSD or you'll go up in smoke. The H-190 is 7.49" and good for less than 285 lb. ft. torque. but probably will survive more with a tiny 1200. Quote Link to comment
S@nt0s Posted March 19, 2008 Author Report Share Posted March 19, 2008 i wont waste my $ on LSD's ill just weld the bad boy. grew up with welded diffs and imma stick to it. then again a welded diff is a "spool" ;) Quote Link to comment
510six Posted March 19, 2008 Report Share Posted March 19, 2008 CA18DET will need low low gears for 1/4 mile. Ideally you want to run our of revs just at the traps. Truck 4.375 H-190 at least, but you'll need an LSD or you'll go up in smoke. The H-190 is 7.49" and good for less than 285 lb. ft. torque. but probably will survive more with a tiny 1200. The only problem is shock loading the axels on slicks probably using some form of anti-lag is going to place a tremendous strain on the axels.I would hate to see intimate contact with a guard rail at the dragstrip because an axel busted. For a street car running an LSD is a good idea as huge loads are placed on the axels turning corners , with a Ford 8.8, Dana 44, Chevy 12 bolt ect... clutch pack or lockers are common and really not as expensive as what could happen to a car if an axel breaks. Quote Link to comment
