Radiant-Designer Posted July 31, 2011 Report Share Posted July 31, 2011 I looked for a min and didnt see a good discription of interchangable parts. I have a 77 620 I just got from Cali, I am in TX on business and see a sliding rear window from an 80 and a 84 (?) parts truck with a 5 speed and newer engine. with AC Ideally I want to go 5 sp, ac and disc brakes. Can I use these finds? I know 79 was when they changed a few things but dont know what they changed. Quote Link to comment
Skib Posted July 31, 2011 Report Share Posted July 31, 2011 the 620 body style ended in 79 anything off the body after that you cant use. theres custom disc brake brackets made by a member F/S somewhere around Ratsun to convert your truck to disk Quote Link to comment
Radiant-Designer Posted July 31, 2011 Author Report Share Posted July 31, 2011 Darn, was hoping the sliding rear window would atleast fit. Quote Link to comment
Skib Posted July 31, 2011 Report Share Posted July 31, 2011 the 80 still had an L motor in it (same as the 620) so if it is really an 80 you can snag motor/tranny stuff from it. Quote Link to comment
ggzilla Posted August 1, 2011 Report Share Posted August 1, 2011 Electric fuel pump Alternator is IR version of the 620 type Quote Link to comment
datzenmike Posted August 1, 2011 Report Share Posted August 1, 2011 The '80 720 would also have the desirable matchbox distributor. Definitely get that. I looked for a min and didnt see a good discription of interchangable parts. I have a 77 620 I just got from Cali, I am in TX on business and see a sliding rear window from an 80 and a 84 (?) parts truck with a 5 speed and newer engine. with AC Ideally I want to go 5 sp, ac and disc brakes. Can I use these finds? I know 79 was when they changed a few things but dont know what they changed. Take a look at the '80 tranny and see if it's a 5 speed. Measure the length of the tranny and if 31.5 or above... and if you can get it for real cheap.... and if it's 2wd, it will drop right into your truck. Put it in and drive home. keep your 4 speed for a spare. The '84 5 speed has to be 31.5" long and 2wd also (and cheap) and you can swap your '77 4 speed front case onto it to convert it for use with your L series motor. It's a bit of bother but if you get it for $50 take it home and do the conversion. FIRST!!! Drain the oil and take a good look at it and the magnet on the drain bung. If the oil is cloudy or milky or if there are chunks of metal or ball bearings on the magnet, walk away. Quote Link to comment
Radiant-Designer Posted August 1, 2011 Author Report Share Posted August 1, 2011 The whole truck is $500 but I'd have to ship it home, don't hve time to drive it back. Quote Link to comment
ggzilla Posted August 1, 2011 Report Share Posted August 1, 2011 Wheels Differential assembly (pumpkin) Quote Link to comment
Radiant-Designer Posted August 9, 2011 Author Report Share Posted August 9, 2011 DatzenMike, you seem to be the expert here, for a '77 620 what 5-speed transmissions can I steal to bolt right onto my L20? Or with very little effort.... Quote Link to comment
datzenmike Posted August 10, 2011 Report Share Posted August 10, 2011 '77and '78 620, the '79 has a wider internal gear set to match the 4.11 diff ratio. '77-'78 280z and first year ('79) 280zx (same ratios as the '77-'78 620) '79-'84 Maxima/810 (same ratios as the '77-'78 620) '80-'83 non turbo 280zx (closest ratio gear set) These will all 'drop in' with the only change being the speedometer pinion gear to keep the speedometer accurate. Quote Link to comment
bbqbill Posted August 10, 2011 Report Share Posted August 10, 2011 i have a sliding rear window. Quote Link to comment
flatcat19 Posted August 10, 2011 Report Share Posted August 10, 2011 What's with all the stealing talk? Quote Link to comment
Radiant-Designer Posted August 11, 2011 Author Report Share Posted August 11, 2011 Is that slider for sale? Stealing is my way of saying taking parts donated from other vehicles, not like I would actually heist them from someone unknowingly. Quote Link to comment
datzenmike Posted August 12, 2011 Report Share Posted August 12, 2011 "Stealing" is my way of saying taking parts donated from other vehicles, not like I would actually heist them from someone unknowingly. Better Quote Link to comment
Radiant-Designer Posted August 12, 2011 Author Report Share Posted August 12, 2011 Send me a message on the slider Sorry, I diddnt want people to think I am going around parking lots with a bag of tools looking for parts, more like junk yards looking for some donor vehicles. Or around where I live, my landlord was a mechanic for many years and has all kinds of parts cars stashed away in the out buildings, mostly little Mazda trucks from the 80's-93 era. He does have an engine and 5 speed from a B210 datsun though.... not sure if that could be useful or not. Quote Link to comment
Ron1200 Posted August 18, 2011 Report Share Posted August 18, 2011 Send me a message on the slider He does have an engine and 5 speed from a B210 datsun though.... not sure if that could be useful or not. The B210 is a 'A' series motor. It does not interchange with the 'L' series motor. The transmission will not work directly with the 'L' series either. Quote Link to comment
