FiveSeventyZee Posted July 28, 2011 Report Share Posted July 28, 2011 Sorry if this is a really common topic but I'm new to 510's and this forum so I sifted the wheel/tire section but didnt see anything. Anyways I'm looking at a set of xxr 522's (the te37 look-a-like sorta rims) but the smallest they come in is 15x7 with a +25 offset and a 4.98" backspacing. Would this fit with say a 1/2" spacer? the 15x8 version has a +0 offset and a 4.5" backspacing which seems like it should fit almost better, but I'm sure that would require flares which I dont really want to deal with on my back doors. the next question is tires. would a 195 or 205 fit better on the 7" rim? I'm not looking for stretched tires but I also dont want my tires bulging super far past the rim lip. I have coilovers on the front and unknown struts in the back. I was told the car had full Troy Ermish suspension but the only Ermish rear setup I found was coilovers and I dont have coilovers in the rear. again, sorry if this is something thats gone over a lot, if it is link me? Quote Link to comment
FiveTenzo Posted July 28, 2011 Report Share Posted July 28, 2011 do you have stock front suspension or 280zx? For the tires i would go 195/50 on a 15x7 for a regular look or really small stretch on a 15x8. but if your low i would recommend 195/45. But you can see what you like better with.... http://www.tyrestretch.com/ Quote Link to comment
FiveSeventyZee Posted July 29, 2011 Author Report Share Posted July 29, 2011 ummm I hav coilovers up front. not sure what kind like I said im new to the dimes. I just bought the car on Sunday. I was told it's Ermish suspension I'll look into it more Quote Link to comment
banzai510(hainz) Posted July 29, 2011 Report Share Posted July 29, 2011 Just buy some ROTA RBs +15 offset (front and rear)If you have 280zx struts. +25 in front if you have stock 510 struts. XXRs are Chinese recycled pop cans wheels. SSRs= Made in Japan Good wheels. ROTAs are not that much better than XXRs but dont need spacers and longer studs which is a pain in the ass on the rear to swap out. Panasports(Japan) are better and and take a 40 curb hit without EXPLODING/Shatering!!!!!!!! IMHO 510s look better with a dished rim. 1 Quote Link to comment
FiveSeventyZee Posted July 29, 2011 Author Report Share Posted July 29, 2011 I was going to get RB's for my z, wasn't really planing on having the same rims on both cars. I think I'm gonna stick with the 280zx rims that came on the car and just get new tires. thanks for the help though. I knew xxrs were knockoffs but never really knew they were that bad Quote Link to comment
banzai510(hainz) Posted July 29, 2011 Report Share Posted July 29, 2011 they aint that bad. But just make it EZ on yourself getting wheels with the correct offset. However Im a firm believer in the right wheels will make or break a Car. See Indy Rusty Ruby car and it just looks Gangsta with the Panasports or the 3 pc wheels. Z wheels just dont cut it.Its almost better to run the early style hubcaps with a samll white wall on a slammed down car!!!!!!! Quote Link to comment
FiveSeventyZee Posted July 29, 2011 Author Report Share Posted July 29, 2011 it's appearance which means it's opinion based. there are trends and styles but every opinion is going to be a little different. that's how it goes Quote Link to comment
banzai510(hainz) Posted July 29, 2011 Report Share Posted July 29, 2011 just hate to see a good car go bad. Put the Z wheels on there and see how this car would look http://www.motormavens.com/2011/07/center-stage-red-hot-datsun-nickel-dime-510-nissan-bluebird/ Quote Link to comment
oregondime Posted July 29, 2011 Report Share Posted July 29, 2011 if you borrow a fender puller u can definitely make room for 8 inch wide up front. theres also rota grid-v's. a te37v replica. http://www.racinglab.com/rota-grid-classic-003.html and the hayashi street replicas called rota shakotan. http://www.racinglab.com/rota-wheel-shakotan.html Quote Link to comment
AZhitman Posted August 2, 2011 Report Share Posted August 2, 2011 Hope the OP doesn't mind me piggybacking onto his thread... 1968 4-door, will be slightly lowered, Z struts... 15X8 25 offset good or no? (I'm sure the info is out there somewhere, but after trying to memorize fitment specs on so many cars, I figured this time I'd defer to the experts)! Quote Link to comment
INDY510 Posted August 2, 2011 Report Share Posted August 2, 2011 1968 4-door, will be slightly lowered, Z struts... 15X8 25 offset good or no? 15x8 +25 with 280zx struts??? ... .. you will need 25mm spacers and fender flares in the front ..... <_< ... .. don't run 8's in the front without flares These are 16x8 +12 with 215/40/16 tires ..... stock rear camber,, rolled fenders, mini-tubs ... Quote Link to comment
5tinguy Posted August 4, 2011 Report Share Posted August 4, 2011 Any pics? What's wrong with the tires? I'll buy your old ZX wheels. Pics? Quote Link to comment
FiveSeventyZee Posted August 4, 2011 Author Report Share Posted August 4, 2011 the tires are just worn out. no tread really left. I can get pics of the rims if youre interested but they're in rough shape. and they're not the alloys from the 81-83. they're the heavy cross ones from the 79-80. Quote Link to comment
AZhitman Posted August 5, 2011 Report Share Posted August 5, 2011 15x8 +25 with 280zx struts??? ... .. you will need 25mm spacers and fender flares in the front ..... <_< ... .. don't run 8's in the front without flares These are 16x8 +12 with 215/40/16 tires ..... stock rear camber,, rolled fenders, mini-tubs ... Indy, you totally lost me here... Were you being facetious about a zero-offset 8" wheel in front? Why would I want flares AND 25mm spacers? Seems to me that if there was a need for flares, I could delete the spacers and be fine. I'm no stranger to "making the car fit the wheels", but the body on this Dime is too pristine to mess up. Therefore, I'm looking for a nice fitment F & R without stretched tires (I don't mind rolling the fenders, that's mandatory on EVERYTHING I own). Thanks man - Appreciate the clarification! :) Quote Link to comment
INDY510 Posted August 5, 2011 Report Share Posted August 5, 2011 . The tires will hit the front strut tubes with a 15x8 +25 ........ you need about 25mm of spacers ...... . but then the wheels will be sticking out too far in the front just run a 15x7 like everyone else .... . . do you like the super MAD camber look??? ...... . cause you need it to tuck 15x8's in the back Quote Link to comment
AZhitman Posted August 6, 2011 Report Share Posted August 6, 2011 Ah, gotcha. So, 15x7 +38 would be a better choice? Quote Link to comment
FiveSeventyZee Posted August 6, 2011 Author Report Share Posted August 6, 2011 +38 is way too hIgh. you want it to be between 13-15 I think so on a 15x7 with +38 I think you would still need a 25mm spacer. but no flares I think that is, I'm no expert which is why I posted this thread Quote Link to comment
INDY510 Posted August 6, 2011 Report Share Posted August 6, 2011 . Stock 510 struts: ... 15x7 +12 to +22 .......... .. . if you have 280zx struts: 15x7 +0 to +12 ..... .. .. that's with 195/45/15 tires Quote Link to comment
AZhitman Posted August 6, 2011 Report Share Posted August 6, 2011 Ooof. I thought my C5 had weird fitments... :( I'm gonna break out in hives if I buy tires that narrow, LOL Quote Link to comment
FiveSeventyZee Posted August 6, 2011 Author Report Share Posted August 6, 2011 you could get 205s on 7" rims easy but you might have rubbing issues Quote Link to comment
FiveSeventyZee Posted August 6, 2011 Author Report Share Posted August 6, 2011 you could get 205s on 7" rims easy but you might have rubbing issues 1 Quote Link to comment
AZhitman Posted August 8, 2011 Report Share Posted August 8, 2011 . Stock 510 struts: ... 15x7 +12 to +22 .......... .. . if you have 280zx struts: 15x7 +0 to +12 ..... .. .. that's with 195/45/15 tires Crap. Enkei doesn't make the 92 in that size. :( http://www.enkei.com/enkei92.html# Quote Link to comment
jdmdime Posted October 5, 2011 Report Share Posted October 5, 2011 interesting... I have a 71 4 door with stock fenders (rolled ofcourse!) On konig rewind 14x7 -9 185/55r14. 280zx struts up front with a 10mm spacer. (=14x7 -19). It also has tein camber plates maxed out on neg camber... I still got more room if I wanted to add a bigger spacer... Quote Link to comment
Uber Deaf One Posted October 5, 2011 Report Share Posted October 5, 2011 Figured I'd post this here instead of make a new thread... I have a set of 15x7 Panasports with 0 offset... 280ZX front struts. What size wheel spacers do I need to get to clear the struts? Quote Link to comment
INDY510 Posted October 5, 2011 Report Share Posted October 5, 2011 . They should fit without any spacers .... .. unless you have huge tires ...... . .DO NOT drive a 510 with any spacers and stock length lug studs.... ... ;) Quote Link to comment
