510 sedan wheel/tire fitment
  • Replies 40
are you sure those are -9 not +9?because if you had -9 with a 10 mm spacer that would mean that your totaloffset would be -19 and backspacing would be under 3 inches. that would leave rim sticking out beyond the fender.
if the wheels are +9 then the offset after spacers would be -1 which I would've thought would still leave rim hanging out past the fender.
  • 3 weeks later...
If you ever want to fix the rear camber/toe ... . then don't run a 15x8 in the back ..... .. . if you like negative camber go with a 15x8 +0 to +12
all you need is 194/45/15 with a 15x8 0 offset with rolled fenders.. .... .. ...umm not that small of a tire and its easy to find.
15x8 0 offset with a 205/55/15 will fit.
Yeah, I want "normal" fitment. I don't mind rolling the fenders, but that's as far as I'll go on this particular car.
3 biggest fitment factors:
- Rear crossmember: slotted, adjustable, or stock camber???
- Front struts: 510 struts, 280zx struts, or other???
- Tire size: Streched, slightly small, perfect, too big baloon tires???
All of these factors change the offset of your wheels by inches not millimeters .... :rolleyes:
