zed1 Posted July 14, 2011 Report Share Posted July 14, 2011 Does anyone have a photo of the original tail gate chain & latch? Is the chain link welded to the truck bed loop? That is the length of the chain? Is the chain threaded in a plastic/rubber sheaf? Thanks, Keith Quote Link to comment
jefe de jefes Posted July 14, 2011 Report Share Posted July 14, 2011 There are hooks at each end of the chain. At least on my 521 there is. You can unhook both ends and remove the chain if needed. Slide the chain through an old bike innertube to keep it from making a racket. See pictures below this post. Yay Quote Link to comment
420n620 Posted July 14, 2011 Report Share Posted July 14, 2011 this pic is from a 521 but I have seen the 520's with and without the sheaf. heres what the hook and welded loop look like, theres a wire to keep the hook always attached to the bed loop. the total length of the chain is 16" where the chain link goes to the hooks. Quote Link to comment
wayno Posted July 15, 2011 Report Share Posted July 15, 2011 These are my 520 chains, they don't have a hole for a wire. Quote Link to comment
dat521gatherer Posted July 15, 2011 Report Share Posted July 15, 2011 As in the previous photo it is good to drill a hole and put a wire in them. After the plastic sleeves wear off the chains will jump off the truck when going over bumps and fall in between the gate and bed hitting the road never to be seen again. I've caught mine a few times with just one hook attached. some 320 chains just for fun. Quote Link to comment
zed1 Posted July 21, 2011 Author Report Share Posted July 21, 2011 Keep me in mind if you ever find a pair for sale. Thanks, Keith Quote Link to comment
dat521gatherer Posted July 22, 2011 Report Share Posted July 22, 2011 if your interested in the second set on the bottom with the bent link let me know. Quote Link to comment
zed1 Posted July 22, 2011 Author Report Share Posted July 22, 2011 dat521gatherer, I am interested in the second pair in photo http://i272.photobucket.com/albums/jj172/dat521gatherer/datsun%20521%20spare% How much do you want for the pair (my business address shipping Zip Code is 75075)? Thanks, Keith Quote Link to comment
boxboy Posted August 21, 2011 Report Share Posted August 21, 2011 I had coated cables on my gate until today. It was warm today and a friend sat down on the gate and slowly sank farther down until the coating on the cables stretched and the cables came loose. So going by an old chain hook I found out in the barn I made some hooks Ratsun style. Here are some pics. They fit fine on the bed side, but the loop on the gate is much smaller. It appears I need to shave quite a bit off in order to make them work. Does anyone have them handy enough to take some measurements side to side and top to bottom? That would help me out in my barnyard fab process. Quote Link to comment
Rocket Dog Posted August 22, 2011 Report Share Posted August 22, 2011 I've had no luck trying to find flat hooks like those - - other than on a marine hardware manufacturer site sold in lots of 1000. :huh: Quote Link to comment
