grant Posted July 11, 2011 Report Share Posted July 11, 2011 I have a 78 620 5spd, and have a leak at the trans where the speedo cable goes in. Am I missing a gasket/o-ring? if so anyone know a part number/source to buy one? thanks Grant Quote Link to comment
Z-train Posted July 11, 2011 Report Share Posted July 11, 2011 O ring is still a dealer item. Quote Link to comment
DanielC Posted July 11, 2011 Report Share Posted July 11, 2011 Second vote on the dealer. You want to check the transmission oil level. It could be overfilled, (not likely), unless some oil was added recently, The oil level could also be low. This is not good for the transmission. Quote Link to comment
datzenmike Posted July 11, 2011 Report Share Posted July 11, 2011 The O ring around the speedo pinion can't disappear, it might leak if removed and put back in. (disturbed) I would more likely think it was the little rubber 'top hat' shaped seal that fits up into the end of the cable sheath. It keeps oil from climbing the inside of the cable and dripping on the floor under the dash. It's about the size of a nickle. If you think it's the O ring, take it to any automotive store and go through their stock for one that matches. . Quote Link to comment
grant Posted July 12, 2011 Author Report Share Posted July 12, 2011 hey guys thanks for the help, the trans has been out before I bought it and I am just finishing a frame off resto of sorts, so the cable was hanging from the bottom of the cab while it was on the hoist so it wouldn't surprise me that one or both of these could be missing. . anyone have a part #? the local nissan dealer is USELESS with datsuns Quote Link to comment
datzenmike Posted July 13, 2011 Report Share Posted July 13, 2011 Can post it after work today. Quote Link to comment
ggzilla Posted July 13, 2011 Report Share Posted July 13, 2011 Take the part down to the Nissan dealer. Tell him it's out of a 1984 Nissan 720. Or takes it to any parts store, and they will match up the O-ring -- or sell you a new cable which is only $15-20. Quote Link to comment
grant Posted July 13, 2011 Author Report Share Posted July 13, 2011 I haven't put it up on the hoist yet but I'm guessing I missing at least one of the pieces so taking it into a dealer/vendor might not be an option. However if no one can find a part # I guess I will have to get the stealership to earn their money! lol Quote Link to comment
datzenmike Posted July 14, 2011 Report Share Posted July 14, 2011 Sorry can only find it as an assy. NAPA has them for about $20. Quote Link to comment
grant Posted July 14, 2011 Author Report Share Posted July 14, 2011 K, thanks mike I really appreciate your time! Quote Link to comment
grant Posted August 6, 2011 Author Report Share Posted August 6, 2011 I thought I should add to this, I figured out the problem. . WAY overfilled by PO. . its all good now thanks again for all the help! Quote Link to comment
datzenmike Posted August 6, 2011 Report Share Posted August 6, 2011 On the level the oil level should be up to the fill hole. The speedo drive pinion only gets splash oiling and the level shouldn't be that high. Thanks for getting back on this. This is a symptom with a cause not that obvious. Quote Link to comment
