Bkhuft Posted July 11, 2011 Report Share Posted July 11, 2011 The guy I bought my car from welded 1/4" plate in the top of the shock tower. anyone have pics on what to cut out to mount my coil overs bolt up? Quote Link to comment
808DA6 Posted July 11, 2011 Report Share Posted July 11, 2011 Might help to post a pic of your dilema. Are you talking about the front upper shock tower? Do you have camber plates? -B Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 take a pic so we can see what is welded up Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 http://i1222.photobu...ft/IMG_0496.jpg Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 Do I need to cut out the same pattern as the top plate? Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 Those are Ground Control camber plates. You don't need any of that steel plate that was tacked in there, especially since you'll have to hog out a bunch of it so that you get both the camber and caster adjustment of those plates. Something is a little screwy, though, because normally there are two pieces of sheet metal overlapping around the top of the tower: If anything, I would perhaps make a steel ring to reinforce around the perimeter where the plates bolt in and call it good. You don't need to double up the whole top with that steel plate. Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 looks like you need trace the to outer slots on that plate cut the towers to mach the plate i think Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 the towers have been cut thats why he has the plate's welded in Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 Thanx. Thats what I thought. I just need a plasma cutter now. Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 the towers have been cut thats why he has the plate's welded in The 3 bolt tabs and inner circle have been cut out, but it doesn't look like the main part has been cut out... Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 i think your right Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 i think the p.o.was going to sandwich for strength Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 I suppose, but OP will have to hog out a considerable amount for those plates to work. They are an older (but cool) GC model. I have the same ones, although nowhere near installed :P The spherical bearing mount is rather large, and needs a lot of space to move around if you install the plates on the top of the tower. Quote Link to comment
Guest kamakazi620 Posted July 11, 2011 Report Share Posted July 11, 2011 Thanx. Thats what I thought. I just need a plasma cutter now. No you DON'T Use a hole saw on both ends and then sawzall the rest YO!!!!! RATSUN!!!! Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 These are a similar new style: Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 I tried the hole saw. It melted down 2 hole saws and didn't hardly cut. That looks like the same kit I have. Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 listen to mat he knows way more then me on this Quote Link to comment
Guest kamakazi620 Posted July 11, 2011 Report Share Posted July 11, 2011 I tried the hole saw. It melted down 2 hole saws and didn't hardly cut. That looks like the same kit I have. Try a Metal hole saw NOT a wood one,unless thats Hardened Cromemoly Quote Link to comment
Wide14u Posted July 11, 2011 Report Share Posted July 11, 2011 No you DON'T Use a hole saw on both ends and then sawzall the rest YO!!!!! RATSUN!!!! this is what i was thinking Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 I tried the hole saw. It melted down 2 hole saws and didn't hardly cut. That looks like the same kit I have. Get something decent, like a lenox bimetal saw. That, low RPM, and cutting fluid/oil. If you do it right, you can hole saw mild steel all day long with the same saw. The tricks are keeping the RPM low and use cutting fluid! The same goes for drilling. Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 The hole saws were for metal. I was even going slow. Quote Link to comment
thisismatt Posted July 11, 2011 Report Share Posted July 11, 2011 Oh, and plenty of pressure too. Quote Link to comment
Bkhuft Posted July 11, 2011 Author Report Share Posted July 11, 2011 It was a lennox bimetal hole saw. I tried to go as slow as possible. I didn't use any oil tho. Quote Link to comment
Dguy210 Posted July 11, 2011 Report Share Posted July 11, 2011 Try a tungsten carbide hole saw. ARTU makes a decent one that is coated all around the edge. Not terrible on the price and OSH sells them. Blows the bimetal hole saws right out of the water. I've used them for cutting lab grade epoxy counter tops, works beautifully. You can barely scratch those with even a good quality bimetal (believe me I've tried) Also, make sure to use a good sized drill and lots of pressure! If you've got a 1/2 inch now is the time to use it. Quote Link to comment
INDY510 Posted July 11, 2011 Report Share Posted July 11, 2011 . One of these holes is not like the others: ......... :unsure: ........... . but I wouldn't trust my life with any of those holes:..... Bondo and fiberglass??? Quote Link to comment
