rojadoja Posted July 10, 2011 Report Share Posted July 10, 2011 So I yanked the hitachi off my truck a couple weeks ago and replaced it with a brand new 32/36 weber. After some tuning, it was like I had a brand new truck. All was good for a week or so and then in a 24 hour period, the idle went from smooth to progressively worse, to no idle at all. The motor will only stay running if I have my foot well into the pedal, and even then it surges. The second I take my foot off the gas, it rapidly dies. I checked all vacuum sources for leaks and checked to make sure I had fuel after the pump and after the regulator. I removed the regulator to verify that it was not the culprit and that did not help. I pulled all my jets and cleaned them out. Any ideas??? Quote Link to comment
Wide14u Posted July 10, 2011 Report Share Posted July 10, 2011 i think you should ask HRH he knows alot on carbs and stuff Quote Link to comment
datzenmike Posted July 10, 2011 Report Share Posted July 10, 2011 Maybe sucked some water through the filter and it's puddled in the bottom of the float chamber or some dirt got in and has partially blocked the jet. You replaced the filter with the new 32/36 swap?? Quote Link to comment
ggzilla Posted July 11, 2011 Report Share Posted July 11, 2011 Could be that the idle circuit is gunked up. Completely remove the idle screw and blow some carb cleaner through it, verify that bubbles come up in the float chamber. Or is it a 32/36 with anti-diesel valve? That may have stopped working. It will fail to idle, but otherwise run OK. Quote Link to comment
Jester Posted July 17, 2011 Report Share Posted July 17, 2011 If it was a progressively worse issue, I would pull the carb and make sure the adapter is still tight. I had one bolt come loose at the bottom and cause a similar issue. Be sure to use a locking compound when putting back together. Quote Link to comment
rojadoja Posted July 30, 2011 Author Report Share Posted July 30, 2011 If it was a progressively worse issue, I would pull the carb and make sure the adapter is still tight. I had one bolt come loose at the bottom and cause a similar issue. Be sure to use a locking compound when putting back together. should i put it back together with or without sealant? Quote Link to comment
