71 510 wagon
squatches
  • Replies 56
But the heat? Look under the driver side of the heater box and find the valve. Sometimes they dont open all the way with the wire controls.
Try using your hand to fully open the valve. you might get soem heat out of it then. Or might leak.
I always leave the valve open but route the heat flap closed to prevent wear on the valve.
that was the problem with it and did what u said and just left it open.
Ill be honest here, those back tires look ass retarded..
haha you should see peoples faces when they see it goin down the road, i get asked what time i run at the strip by all the rednecks around here lol.
i have the matching wheels for the rear in the shop but im running these for now for shits and giggles, longchamps would be nice tho.
  • 1 month later...
  • 1 month later...
today while getting the 510 ready for the ka my add kicked in and i decided to mess around with the steering column from the 240sx. with a little work it fits right in, so now i have a tilt column and all the 240 controls. soon the whole 240 dash will be in the car as well as all the wiring harness
this is tilted almost all the way up but the ignition switch hits the guage bezel.
up close of ignition hitting
this is tilted all the way down
to get it to bolt up to the original 510 dash a plate would have to be made, only one bolt hole would line up with the original mount location.
and this is it connected to the steering box.
  • 5 weeks later...
been working on the wagon for the past few days and got the intake manifold cleaned up and some new hoses on it now waiting on gasket and seal kit to get here. Also cut 240sx dash to fit, and finished cleaning up the 240 harness to go in wagon.
Intake
Dash
  • 8 months later...
ok so its been a little while since ive worked on the 510 but now thw engine is in and wired. now ive got to put all the bits and pieces back on it and make the transmission brace.
and NAchatty poking things as usaul
all the wiring its still a mess this is only temporary until i get everything in and running
  • 4 weeks later...
started scraping out the sound deadening, found more sheet rock tape and putty.
then found my long lost front tire thru my floorboard.
more rust
rust cut out
trans tunnel cut for transmission
aluminum radiator with flexalite fans (aquired for $40 bucks) B)
radiator in car, theres even room for the intake over it.
going to be making seat brackets for these when i start redoing the floorboards.
also putting in this ebrake, i was going to use the one in the pic above but it just didn't fit/look or feel right.
  • 3 months later...
i finally got around to wiring up the 240sx dash and steering column into the 510.
this is all the wires and fuses i ended up keeping.
here it is lit up in the floor of my room.
i still need to solder all the wires together and hook the main wires of the car to them.
  • 6 months later...
scored a free a/c unit from a buddy he had it sitting in his shed for awhile, so it was hella dirty when i got it but cant complain for free.  took it apart and cleaned it real good made it look as new as possible while i was at it.  i dont have any before pics but heres after cleaning and reassembly.
what are you guys with ka swaps doing for the a/c lines?
he gave me a spare hatch aswell, im prob gonna paint weird stuff on it and stick it on the car.  he also has a 510 tach that im going to get from him later.
oh and what is this hole for next to the fuse box?
Ive been wondering what the hole was for since I got the car, there was nothing going into it and it wasn't plugged.  I went and looked at 2 510's in a junkyard and neither of those had it either.   It doesn't look like someone drilled it out, its the same size as the hole the harness would normally go thru and there's no rough edges on it.
