Topher88 Posted June 24, 2011 Author Report Share Posted June 24, 2011 Well tomorrow I may be pulling the motor and taking it to a shop to be re built. I want a reliable anging and for the price it would cost to get anything running l20b I can just get mine re built. I really want to get some more power out of it but still want it to be very reliable and I know there is a fine line when it comes to that. Quote Link to comment
Siqx20 Posted June 24, 2011 Report Share Posted June 24, 2011 That sounds like a smart move. I hoped mine was gonna last longer then just randomly completely went and started dumping oil out of my crank case. Quote Link to comment
Topher88 Posted June 24, 2011 Author Report Share Posted June 24, 2011 Well I just got a quote of $1400 for a compleat re build on the engine so for that I could get close to an SR and get a decent KA.. Idk time to start re planning my engine aproch. Any ideas guys? Quote Link to comment
Siqx20 Posted June 24, 2011 Report Share Posted June 24, 2011 give me 300 and i will rebuild it for u ;) u jst gotta pay parts and machine shop work. Quote Link to comment
jon521 Posted June 24, 2011 Report Share Posted June 24, 2011 i have a newbie question....where is the crankcase breather located on L motors? Quote Link to comment
datzenmike Posted June 25, 2011 Report Share Posted June 25, 2011 On the driver's side of the block behind the exhaust manifold. L16/18s tend to come straight out from the block and past the exhaust manifold. There is a hose that connects the pipe to the PCV valve on the intake manifold. L20B (and Z series) come out the top and the pipe wraps around the back of exhaust manifold with hose to the PCV valve. . Quote Link to comment
albyneau Posted June 25, 2011 Report Share Posted June 25, 2011 On the driver's side of the block behind the exhaust manifold. . Sooo Mike~ just exactly what kind of grass you mowin...? :blink: :lol: JK, my friend, JK!!! :lol: Unusual color for an engine paint.... Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 give me 300 and i will rebuild it for u ;) u jst gotta pay parts and machine shop work. Machine work will cost 300+ and parts will cost around that too. Thanks for the offer man but thats still a KA swap right there. If I can't find a cheap decent running L20b then I'll just have to put my project on hold and start my saving for a KA swap in the 510 Quote Link to comment
ggzilla Posted June 25, 2011 Report Share Posted June 25, 2011 You can buy a complete good running Silvia with Z20 for $250 in Tigard Oregon ... Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 Just did a compression test #1 145 #2 135 #3 149 #4 150 Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 Any reason why I can't fit the crank case breather to the valve cover breather? Just recycle the oil? Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 Or plug the crank case breather and hook the valve cover breather to the PCV? Quote Link to comment
Topher88 Posted June 25, 2011 Author Report Share Posted June 25, 2011 I check my PCV and it was good and hooked up a breather to the PCV and had a t so I fit one end of the t to a catch can and made sure it was air tight then I hooked it up to the PCV and crank case and oil oozed into the can. Since my compression isn't that bad is the one that 135 the reason I have so much oil coming out??? Quote Link to comment
Siqx20 Posted June 25, 2011 Report Share Posted June 25, 2011 What's the smoke smell like? If it smells like exhaust ur not gonna want to put that back into ur crank case. It will just continue to contaminate the oil further. Ur pvc obviously isn't going to be able to compinsate for that much crank case pressure. I would just take a hose from your crank case and valve cover and run it into the fender or ground. Vent it to the atmosphere. Truck will contine to smoke if not smoke worse cause its going straight to the atmosphere but atleast its not putting that shit back in your motor. Do a oil change to get rid of the already contaminated oil and just roll with it. Mean while I would start saving for a rebuild to fix the problem or source a new better running L motor. Quote Link to comment
Siqx20 Posted June 25, 2011 Report Share Posted June 25, 2011 I would di a cylindar leak down check. Better then a compression test. Figure out where bad seal is that is over pressurizing ur crank case. Whethr it be valves, rings, or something else. Quote Link to comment
DanielC Posted June 25, 2011 Report Share Posted June 25, 2011 My factory service manual for L-13 L16, and L20(a) engines says compression should be 171, with a minimum of 159. You could do a leakdown test if you want, but I think it will just confirm you need to do some engine work. Quote Link to comment
ggzilla Posted June 26, 2011 Report Share Posted June 26, 2011 135 to 150 is all cylinder within 10% of each other. This is good. Now do a leak-down test, or a wet compression test. Quote Link to comment
Topher88 Posted June 26, 2011 Author Report Share Posted June 26, 2011 so today i did an oil change on the old girl and guess what i figured out?? turns out the dip stick that the PO used was an L16 dip stick or some other. Picked up an L20b dip stick and It was about 3 - 4 inches longer then the one i had. That explains why oil was spurging out the crank case. now she dosnt spit oil or even smoke with the PCV valve and breather hooked up. YAY. Now i need to see why she is getting in the 210 temp. i purchased a 180 thermostat so ll put that in and see what it does. think thats a good temp for a southern cali 510? Quote Link to comment
datzenmike Posted June 27, 2011 Report Share Posted June 27, 2011 Sooo Mike~ just exactly what kind of grass you mowin...? :blink: :lol: JK, my friend, JK!!! :lol: Unusual color for an engine paint.... I have no idea who's L16 that is. :lol: (or what he's smokin') A picture is a picture is a picture. Quote Link to comment
RAlly_DatoB210 Posted July 6, 2011 Report Share Posted July 6, 2011 i have filters, but i have a custom manifold with ITB's so i nowhere to hook that stuff up. yeah you also have a nice set of 46mm su's hope there isnt a mistake but i believe they are mine. hopefully this gets sorted out Quote Link to comment
