Stfwells Posted June 9, 2011 Report Share Posted June 9, 2011 So I ordered a cheap slave cylinder from the local parts store. While bleeding the system, the rod and rod seat pushed out of the housing. This happened just after I had evacuated the air from the line and went for a test push for pedal feel. My questions are: Do you guys think I should just rebuild the original? From whom and where do you guys recommend I purchase a quality rebuild kit or new slave cylinder? And do you guys think this could be attributed to anything other than an old unit and shitty new part happenstance? I just want to make sure I'm not overlooking anything... Oh...here's some titties... Quote Link to comment
I'm BLUE Posted June 9, 2011 Report Share Posted June 9, 2011 This happened to your new one or old one !? ,,, They are soooooo cheap ,,, I always just get a new one ! :D If this happened to your old one ,,,, just install the new one ,,,, If this happened to your new one ,,, do you have the threaded rod-end/push-rod end ,,,, in correctly ? :huh: Quote Link to comment
Stfwells Posted June 9, 2011 Author Report Share Posted June 9, 2011 This happened to your new one or old one !? ,,, They are soooooo cheap ,,, I always just get a new one ! :D If this happened to your old one ,,,, just install the new one ,,,, If this happened to your new one ,,, do you have the threaded rod-end/push-rod end ,,,, in correctly ? :huh: Yeah...it was the new one. And that's why I ordered it...cause it was so cheap. ^_^ I installed the rod correctly. But I had to adjust it out, to account for the slightly different shape and seat depth of the new one. I don't know if this is even possible, but I guess I'm concerned about over-pressurization.?. Quote Link to comment
Stfwells Posted June 9, 2011 Author Report Share Posted June 9, 2011 So I went out and removed the new slave cylinder. Took a look at it, everything seemed fine so I reassembled it and reinstalled. Started the bleeding procedure and it started to piss, right off the bat. :angry: It's pissing from out of the boot during the clutch depression stroke...just like the old one. Any thoughts, ideas or recommendations? Oh...and @ss oics... Quote Link to comment
Stfwells Posted June 9, 2011 Author Report Share Posted June 9, 2011 Well...fuck. I guess tits and ass won't get you to far around here. I was hoping for some sort of thought or opinion from someone. Shit, somebody call me a limp dick so I know you guys are at least out there. Quote Link to comment
datzenmike Posted June 9, 2011 Report Share Posted June 9, 2011 1st choice get a new one from a dealer. 2nd choice get a used one from another car 3rd get a rebuilt from Shucks, beck Arnley, Lordco whatever... 1st choice for rebuilding is with a kit from Nissan 2nd choice is a kit from anywhere else. 1 Quote Link to comment
metalmonkey47 Posted June 9, 2011 Report Share Posted June 9, 2011 I rebuilt mine. Payed $1 for the kit on Rock Auto. If you have no pitting inside the old slave, then rebuilding it only makes sense. Cheaper, and more reliable. Quote Link to comment
banzai510(hainz) Posted June 9, 2011 Report Share Posted June 9, 2011 I myself I would try to put it back together. if still leaks get another new one since they are cheap. rewbuilt kits suck in my opinion. I keep a rebuilt kit in the car if its old and going to travel far in CASE one goes bad. If it over extended then I guess it your fault. I cant see how they can do that. unless a short rod or something. But yes makes sure the rod put up and th rod is fully seated inside the slave housing. Jap made Tokico and Nabcos are thew best to get.the rod your using seems a little funky or a rigged up job. I never seen that many threads on thru the fork before. wonder if you have a mismatched sleeve on the T/O bearing. 1 Quote Link to comment
Stfwells Posted June 10, 2011 Author Report Share Posted June 10, 2011 Thanks guys...turns out I had my rod length all fucked up. Adjusted it, and it seems to be working fine. Not the first time I've had rod length issues :P. Quote Link to comment
LeX Posted June 11, 2011 Report Share Posted June 11, 2011 Thanks guys...turns out I had my rod length all fucked up. Adjusted it, and it seems to be working fine. Not the first time I've had rod length issues :P. it's the motion of the ocean :P 1 Quote Link to comment
