Any interest in intake manifold swap?
I have a intake manifold for dual carbs weber/dellorto side draft that fits truck version of l20...It is tooo tall for my 510. I need the car version so my hood will shut. Anyone have a shorter intake (Dual Carbs)interested in trading?
  • Replies 13
I have an intake from a 510. Still not sure if it will fit the 620 with the brake booster.
Do you have any pic's of the intake? I can't think of why it would cause a hood interference?
Damn that is HIGH.
But Im thinking a weber DGV and a adapter and aircleaner will still be higher
do you think the carbs will be higher than this set up? as this the carb is higher than the aircleaner, But this is a l16 a L20 will be about 3/4 to 1ich higher in a 510 using 510 motor mounts(that bolt to the engine)
Maybe can see a brake master in the way with the airhorns
test fit it
I heard the higher intake worked better. more effiecent
There's a pic of my carbs and intake. I haven't tried fitting them yet.
I can take a pic at a different angle if it will help.
Thats the nissan comp manifold I have the same one on my wagon. That thing is really long, I had clearance with the master cylinder. With mikunis and short air horns the minifold car setup mesured 11 1/2". On my brothers 620 from the cylinder head to the booster it measured a bit under 11 1/2". I don't know if that will help.:)
